I've just upgraded Ubuntu 18.04 to 20.04. Unfortunately, some things such as OBS component has been broken.
Here are some of the log captured in /var/log/syslog
Aug 23 10:13:38 pc com.obsproject.Studio.desktop[5817]: [h264_nvenc @ 0x55a8e843d200] Driver does not support the required nvenc API version. Required: 9.1 Found: 8.1
Aug 23 10:13:38 pc com.obsproject.Studio.desktop[5817]: [h264_nvenc @ 0x55a8e843d200] The minimum required Nvidia driver for nvenc is 435.21 or newer
Aug 23 10:13:38 pc com.obsproject.Studio.desktop[5817]: warning: [NVENC encoder: 'simple_h264_recording'] Failed to open NVENC codec: Function not implemented
I've updated the system with sudo apt update -y && sudo apt upgrade -y but did not fix the problem.
What should I do to fix this?
Open the terminal and type:
sudo apt update
sudo apt-get remove '^nvidia'
sudo apt autoremove
sudo apt install nvidia-driver-435 # or alternatively nvidia-driver-440
sudo reboot
If after these coimmands you still get a Failed to open NVENC codec: Function not implemented error message see How to install / compile NVENC in Ubuntu?.
karel
  • 122,292
  • 133
  • 301
  • 332
