I have an Asus AMD Ryzen7 equipped with Windows10 installed on /dev/nvme0n1 . I would like to install Ubuntu 20.04 on an external SSD /dev/sda .
Using an Ubuntu Live USB /dev/sdb, I tried several times, in vain, to install Ubuntu on the external SSD. The install process seemed to go fine and smooth, however, at the last stage after installation complete and before rebooting, I got the following message:
Executing grub-install /dev/nvme0n1 failed. This is a fatal error
Please note that:
  • The disk /dev/nvme0n1 has an EFI partition over /dev/nvme0n1p1 containing the Windows Boot Manager.
  • Over the external SSD disk /dev/sda, I defined another EFI partition over /dev/sda1. This EFI partition will allow the external SSD to become Ubuntu bootable independantly of the current PC. I defined an ext4 partition /dev/sda2 mount to /. This partition will hold the entire Ubuntu system. I defined a FAT32 partition /dev/sda3. This partition will be shareable partition between Ubuntu and Windows10.
I would like that the Ubuntu installation (grub) add an Ubuntu boot entry inside the Windows Boot Manager. So during the installation, I chose /dev/nvme0n1p1 as a "device for boot loader installation". And I got the error message :
Please find the boot-repair report at the following link
https://paste.ubuntu.com/p/gG6ykKD9nR/
Moreover, I made a 2nd try by choosing /dev/sda1 as a "device for boot loader installation". I got a similar error message :
Executing grub-install /dev/sda1 failed. This is a fatal error.
I also checked that the "fast boot" and "secure boot" are disabled.
Any help would be greatly appreciated.
Nmath
  • 12,664
