I was trying to install mega using dpkg and now, I have a broken package in my system, and when I run the Synaptic Package Manager and click on "Mark for complete removal" on the package, it gives me a warning box that says this will affect other packages.
The broken package is megasync:
Also, I am seeing this annoying white dash sign in a red circle on the top-right of my screen, and it says:
An error occurred, please run Package Manager from the right-click menu or apt-get in a terminal to see what is wrong. The error message was :'Error:BrokenCount>0'. This usually means that your installed packages have unmet dependencies. ..
Now, how should I go about it and remove the broken package completely from the system without messing up my system?
Edit:
sudo apt update
voidRealm@voidRealm:~$ sudo apt update
Get:1 http://in.archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Hit:2 http://dl.google.com/linux/chrome/deb stable InRelease        e
Hit:3 https://deb.nodesource.com/node_12.x focal InRelease
Hit:4 http://in.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 http://in.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:7 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:8 http://archive.canonical.com/ubuntu focal InRelease
Ign:9 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.0 InRelease
Hit:10 http://ppa.launchpad.net/dawidd0811/neofetch/ubuntu focal InRelease
Err:11 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.0 Release
  404  Not Found [IP: 99.86.42.60 443]
Hit:12 http://ppa.launchpad.net/maarten-baert/simplescreenrecorder/ubuntu focal InRelease
Hit:13 http://ppa.launchpad.net/obsproject/obs-studio/ubuntu focal InRelease
Hit:14 http://ppa.launchpad.net/ubuntuhandbook1/apps/ubuntu focal InRelease
Reading package lists... Done
E: The repository 'https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.0 Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
sudo-apt upgrade
voidRealm@voidRealm:~$ sudo apt upgrade
^Citing for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 4557 (synaptic)... 16s
akhilD
  • 184
It's a classic misunderstanding:
To apt, a broken package does NOT mean that it's corrupt or defective. It's merely an incompatible version.
Generally, DON'T try to remove or uninstall "broken" packages. Sometimes you can, but sometimes, doing so will remove other packages. It's that apt dependency chain.
This kind of error usually occurs when folks read advice on the internet about how to get the newest or latest software.
The best way to fix the problem is to undo whatever changes you made: Restore the original Ubuntu repositories and remove the non-Ubuntu sources and PPAs that provided the broken package(s). Then it's usually possible to tell apt to (re-)install the compatible version of the broken package, which solves the problem.
user535733
  • 68,493
