You know in windows to change the language of keyboard is shift + alt. is there any shortcut for this in ubuntu ? Because i cant find one and its super annoying to switch it manually! Thanks for answering !
Asked
Active
Viewed 4,378 times
In the standard Ubuntu desktop, with Gnome Shell, Super+Space is the default keyboard shortcut to switch between input sources (i.e., different installed keyboard layouts).
If you have more than a few layouts installed, the keyboard shortcut Super+Shift+Space will be valuable to cycle in reversed order through the available input sources.
vanadium
- 97,564
Refer to the official Ubuntu documentation for your version. You can find the answer to your question by opening the Help program and typing Use alternative input sources in the search bar.
You can also access those documents online:
- for Ubuntu 16.04 LTS Xenial https://help.ubuntu.com/16.04/ubuntu-help/keyboard-layouts.html
- for Ubuntu 18.04 LTS Bionic https://help.ubuntu.com/18.04/ubuntu-help/keyboard-layouts.html.en
- for Ubuntu 20.04 LTS Focal https://help.ubuntu.com/lts/ubuntu-help/keyboard-layouts.html.en
