I've been using Ubuntu 20.04 for several days and then at one point when I tried to login I was met with a "Oh No! Something has gone wrong and the system can't recover. Please log out and try again." message and if I clicked it, it sent me back to the login screen. In addition to this screen I also had access to my terminal, I think because I have it setup to open on login. Rebooting did not help.
I'm a noob to linux so I'm going to list everything I tried even if some of it isn't relevant. Sorry for the long post.
The only "big" thing I remember doing before I logged out/ shutdown my computer before I started getting these messages was I installed this vim plugin to enable opencl syntax highlighting by git cloning it in ~/.vim/pack/plugins/start the syntax highlighting was working fine before I logged out. I was able to remove the ~/.vim/ and ~/.vimrc files from my home directory but it did not help.
Then I tried this solution by doing
sudo apt update && sudo apt dist-upgrade
sudo apt clean && sudo apt autoremove && sudo reboot
It worked without any problems but I still could not login.
I had installed rocm opencl previously by following this installation guide, and it was working fine, but I thought maybe this could be causing some problems for some reason, so I uninstalled it from the same guide. Some of the directories weren't removed because they had stuff in them so i manually removed the last few directories in /opt/rocm so now my /opt directory is empty. This still did not fix my problem.
From this post I found out that maybe logging in as a different user could work. So I created a new test user and logged in and it worked! I think this means that my problem is with my main user configuration and not with my system but idk. From this test user I su - main to my main account and tried to reinstall gnome following this post, because I read somewhere that this might help so first I did:
sudo dpkg-reconfigure gnome-shell
which still gave me the error message on my main user account when I tried logging in, so then I tried:
sudo apt remove gnome-shell
sudo apt install gnome-shell
This still did not fix my issue when I tried logging in with my main account but now when I log in with my test account the dock on the left side is hidden by default, and I can only access it with the windows key or by pressing activities in the top left. I made a test2 account to see what would happen and again the dock was hidden. I am currently writing this from my test2 account.
The next thing I was going to try was to remove configuration files in my main account and see what happens but I'm not sure what I should remove and how to do this safely and if this is even a good idea at all.
I am not opposed to backing up my files and reinstalling ubuntu because I have only been using it for a few days and I need to reinstall rocm opencl again either way. However, I would still like to know what happened and if there is a way to fix it so that this doesn't happen again (and if it does so I know how to fix it) when I would be more opposed to reinstalling ubuntu in the future.
Sorry for the long post, I really appreciate you taking the time to read it.
Edit: I decided to just create a new admin account and remove my old one and reconfigure everything. So far there have been no login issues or anything. I was also able to get the dock to appear again by doing: sudo apt install gnome-shell-extension-ubuntu-dock Thanks for all your help everyone I couldn't have done it without you!
Had the same problem. I tried every solution from this point that the option that finally worked was reinstalling gnome-shell.
To give you some context when running into this problem yourself:
First start your PC after that press the ESC Button just after your manufacturer logo. This will get you to the boot options for Ubuntu, from here you can start into recovery mode. This mode allows you to start a root shell and execute the needed commands.
vince
  • 103
-1
I was having the same issue, debugging it since yesterday.
Creating another user did work as a temporary fix. So it really seems like some configuration issue.
Renaming / removing "~/.local/share/gnome-shell/extension-updates" (or "~/.local/share/gnome-shell") and trying to log back in fixed it for me. (I have to double-check later, as I'm currently accessing my desktop via RDP)
The folder itself contained only "extension-list@tu.berry", which seems to be the offending extension.
According to the Gnome extensions page, there appears to be someone else who experienced issues with this extension as of yesterday. I'll contact the dev later if I find the time to do so and I don't forget about it.
