Situation
I have recently installed Ubuntu 20.04 LTS on a new HP 17-ca1124ng laptop.
Unfortunately, however, I realized that the OS will boot only when the laptop is charging. When trying to boot Ubuntu without having the laptop on a charger, I am asked to decrypt the hard drive (which works) but then the boot process just hangs on a black screen. Booting while on charger, then disconnecting from the charger works perfectly fine.
Resolution attempts
  • new install of Ubuntu 20.04 did not cut it
  • BIOS reset did not cut it
  • changing GRUB_CMDLINE_LINUX_DEFAULT in /etc/grub/default to
    • GRUB_CMDLINE_LINUX_DEFAULT="quiet splash dis_ucode_ldr" and running sudo update-grub did not cut it
    • GRUB_CMDLINE_LINUX_DEFAULT="splash" and running sudo update-grub to maybe get some info on what fails but everything is flagged as OK during boot
Questions
  1. Is this a hardware or software issue?
  2. If this is software related, how do I fix this?
Thanks in advance for your help!
Similar issues
apitsch
  • 342
Edit your /etc/default/grub as such
GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash iommu=soft”
don't forget to...
sudo update-grub
then reboot.
Might be of interest for those running Ubuntu 20.04 on Dell computers:
I had the same problem on a Dell Latitude 7300 and the accepted answer did not work for me, however the answer from the Dell community forum mentioned in the original post did work:
Edit /etc/default/grub setting GRUB_CMDLINE_LINUX_DEFAULT="quiet splash dis_ucode_ldr" and run sudo update-grub.
DimB
