The problem, function key does not change the brightness of my screen, the slider moves but nothing changes.
The brigthness being always at max, I use this as a work around
xrandr --output eDP-1 --brightness .5
My setup
Lenovo Legion
CPU: Intel I5 9300H
GPU: TU116M Nvidia GeForce GTX1660 Ti + Intel UHD Graphics 660
The things I have tried:
  • Changing Nvidia Prime settings, (economics, on-demand, performance)
  • Switching between Intel and Nvidia GPU with nvidia-settinga
  • Changing Grub values GRUB_CMDLINE_LINUX_DEFAULT= and GRUB_CMDLINE_LINUX=
Many post says many different things about what to put in those values, since I do not understand, maybe I did not put the right values in it
  • Changing drivers in "Additional drivers" section of settings
  • Updating drivers for Nvidia
  • Upgrading from Ubuntu 18.04 to 20.04
  • Adding this section to /usr/share/X11/x.conf.d/10-nvidia.org
  • settings > power > screen brightness slider, it slides but brightness doesn't change
Section "Device"
    Identifier "Device0"
    Driver "nvidia"
    VendorName "NVIDIA Corporation"
    BoardName "<your graphic card as it named in your system>"
    Option "RegistryDwords" "EnableBrightnessControl=1"
EndSection
Maybe I did not find the right name to fill for Boardname,Ubuntu would not boot until I removed those lines
I'm looking for new things to try, things I could have done wrong in the previous step, a fix, anything that could prevent my eyes from burning looking at my screen
kopo
  • 31
I could find the solution thanks to elmclose comment
I had to change the line GRUB_CMDLINE_LINUX_DEFAULT= in /etc/default/grub
I originaly added acpi_osi=linux and acpi_backlight=vendor to the line
Changing from acpi_backlight=vendor to acpi_backlight=video worked for me
Save the file, run sudo update-grub, reboot, it should work just fine now
kopo
  • 31
