I used the answer from this post to make a GRUB menu entry to boot from a USB stick that had Ubuntu 18.04 on it:
How to add a GRUB2 menu entry for booting installed Ubuntu on a USB drive?
It says to put this in /etc/grub.d/40_custom: (Use your own UUID)
menuentry "Boot from LIVE USB Drive" {
   search --set=root --fs-uuid CA05-C6FF
   linux ($root)/casper/vmlinuz boot=casper quiet splash --
   initrd ($root)/casper/initrd
From a script, you can edit /etc/defaults/grub:
GRUB_DEFAULT="Boot from LIVE USB Drive"
And then execute:
sudo update-grub
In the script you can execute:
sudo reboot
and the computer will boot from the USB stick - IF you are running Ubuntu 18.04 on the USB stick. If you are running 20.04, GRUB stops and says, "error: no such device: CA05-C6FF"
blkid shows the UUID is correct: dfr@m9kmission:~$ blkid
/dev/sdb1: LABEL="UBUNTU 20_0" UUID="CA05-C6FF" TYPE="vfat" PARTUUID="1246c10c-01"
Any idea how to fix this???
Boot USB from Internal GRUB
I have three flash drive menuentries in my grub.cfg file:
menuentry "Ubuntu - flash drive" {
    set root=(hdX,Y)
    set gfxpayload=keep
    linux ($root)/casper/vmlinuz  file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash ---
and
 search --set=root --fs-uuid xxxx-xx-xx-xx-xx-xx-xx
    set gfxpayload=keep
If the first does not work, (sometimes got to fiddle with (hdX,Y) if 0,1 is not right), I add the correct UUID to the second.
I did not need to edit edit /etc/defaults/grub
If your USB is an ISO booter a standard menuentry including set root for loop mounting ISO's should work
menuentry "Ubuntu-20.04 64-bit ISO" {
    rmmod tpm
    set root=(hd0,1)
    set isofile="/ubuntu-20.04-desktop-amd64.iso"
        loopback loop $isofile
        linux (loop)/casper/vmlinuz boot=casper iso-scan/filename=$isofile quiet splash --
        initrd (loop)/casper/initrd
Again you may have to fiddle with set root location.
You can also add fsck.mode=skip after quiet splash if you want to get rid of the file check.
C.S.Cameron
  • 20,530
  • 78
  • 125
