12
I'm trying to install GDAL and GDAL development libraries on Ubuntu 20.04 with the following commands (source: https://mothergeo-py.readthedocs.io/en/latest/development/how-to/gdal-ubuntu-pkg.html):
sudo add-apt-repository ppa:ubuntugis/ppa
sudo apt-get update
sudo apt-get install gdal-bin
ogrinfo --version
GDAL installs successfully and it returns:
GDAL 3.0.4, released 2020/01/28
After that, I tried installing GDAL development libraries:
sudo apt-get install libgdal-dev
It returns the following error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libgdal-dev : Depends: libpq-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages.
What is the problem here? I read somewhere that "UbuntuGIS stable ppa (launchpad.net/~ubuntugis/+archive/ubuntu/ppa) does not have any 20.04 packages." Is there a workaround for this? Everything works if I try it on Ubuntu 18.04.
You don't need to add apt repository for ubuntu 20.04. Just do:
  1. sudo apt update.
  2. sudo apt install libpq-dev gdal-bin libgdal-dev
Mitch
  • 316
The Solution that worked for me is as follows
I was trying to install libgdal-dev and also had following error:
libgdal-dev : Depends: libarmadillo-dev but it is not going to be installed
               Depends: libdap-dev but it is not going to be installed
               Depends: libgeotiff-dev (>= 1.5.0) but it is not going to be installed
               Depends: libhdf4-alt-dev but it is not going to be installed
               Depends: libhdf5-dev but it is not going to be installed
               Depends: libkml-dev but it is not going to be installed
               Depends: liblzma-dev but it is not going to be installed
               Depends: default-libmysqlclient-dev but it is not going to be installed
               Depends: libnetcdf-dev but it is not going to be installed
               Depends: libpng-dev but it is not going to be installed
               Depends: libspatialite-dev but it is not going to be installed
               Depends: libtiff-dev but it is not going to be installed
I have use aptitude to interactively resolve dependencies. You can also use the GUI ncursis version only running aptitude in terminal. It will ask to keep the current version, select n (No) and it will tell you how to resolve next. In this case it suggested downgrading packages, select 'Y' and it will install libgdal-dev successfully.
$ sudo aptitude install libgdal-dev
... ... Keep the following packages at their current version:
  1.  default-libmysqlclient-dev [Not Installed]
  2.  libarmadillo-dev [Not Installed]
  3.  libdap-dev [Not Installed]
  4.  libgdal-dev [Not Installed]
  5.  libgeotiff-dev [Not Installed]
  6.  libhdf4-alt-dev [Not Installed]
  7.  libhdf5-dev [Not Installed]
  8.  libkml-dev [Not Installed]
  9.  liblzma-dev [Not Installed]
  10. libmysqlclient-dev [Not Installed]
  11. libnetcdf-dev [Not Installed]
  12. libpng-dev [Not Installed]
  13. libspatialite-dev [Not Installed]
  14. libtiff-dev [Not Installed]
  15. uuid-dev [Not Installed]
  16. zlib1g-dev [Not Installed]
Accept this solution? [Y/n/q/?] n The following actions will resolve these dependencies:
 Downgrade the following packages:
  1. liblzma5 [5.2.4-1ubuntu1 (now) -> 5.2.4-1 (focal)]
  2. libuuid1 [2.34-0.1ubuntu9.1 (now) -> 2.34-0.1ubuntu9 (focal)]
  3. zlib1g [1:1.2.11.dfsg-2ubuntu1.2 (now) -> 1:1.2.11.dfsg-2ubuntu1 (focal)]
Accept this solution? [Y/n/q/?] Y
Now just to check run sudo apt install libgdal-dev
libgdal-dev is already the newest version (3.0.4+dfsg-1build3).
Hope this helps!!
