I just built a new PC, and would really like to run Ubuntu 20.04 LTS, as I've never used Linux before and want to use it. For three days now, I have not been able to install it onto my hard drive. Here are the components of the computer.
Motherboard: MSI b550-a pro CPU: Ryzen 5 3600 Graphics Card: AMD Radeon RX 580 Hard drive: Adapta sxg6000 M.2 nvme
The steps I have used to install Ubuntu are 1) Burn ubuntu ISO (from ubuntu website) onto a flash drive, boot to the flash drive, and attempt the install.
I have tried multiple different USBs, I have tried Ubuntu, Mint, and Elementary OS, I tried a sata connected SSD and a nvme M.2 hard drive, but they all have the same result.
The install starts off well, and then I get the error 'Executing 'grub install /dev/nvme0n1' failed. This is a fatal error.', When I tried to SSD the error was 'Executing 'grub install /dev/sda' failed. This is a fatal error.
I feel like I've tried just about everything. I really don't know what to do. This is my last resort. My last guess is that perhaps the motherboard is incompatible with Linux. Do you guys have any suggestions?
[Also worth noting -- I'm not super techy, if you need a log of info, please let me know how to obtain the data]
Thank you to whoever tries to help me. Seriously.
Edit 1: I forgot to mention, when I boot to the grub menu where I can select "Ubuntu", "Ubuntu (graphics safe)" etc., I edit using "e" and add nomodeset and acpi=off. Originally I couldn't even boot to the flash drive, but after that fix, I was able to get to the "Try/Install Ubuntu" phase, but my progress pretty much ended there.
BriggsR
