I want to setup micro as the default editor in Midnight Commander (I was using the default nano). I've installed micro as a snap.
I deleted the file .selected_editor in my home user folder so now it gives me a list of editors each time that I press F4, but micro does not appear in this list.
Select an editor.  To change later, run 'select-editor'.
  1. /bin/nano        <---- easiest
  2. /usr/bin/vim.basic
  3. /usr/bin/mcedit
  4. /usr/bin/vim.tiny
  5. /usr/bin/code
  6. /bin/ed
Choose 1-6 [1]:
What can I do to make micro my default editor?
I'm using Ubuntu MATE 18.04 LTS, my terminal is Terminator and my Micro version is 2.0.6.
To use another editor than those proposed by mc, just choose any of the options so mc creates the ~/.selected_editor file.
Then edit that file and replace the path to the executable in it to the editor you want to use. You need to use a command line that would also work in a terminal.
Sebastian
  • 1,451
  1. Install micro (for e.g., with brew).
  2. Disable mc internal editor.
  3. Use select-editor command (already there, from sensible-utils package; instead of editing any file directly).
Pablo Bianchi
  • 17,371
