I am trying to (unsuccessfully) install Inkscape on Xubuntu 16.04.
If I do sudo apt-get install inkscape this is what I get:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
inkscape : Depends: libmagick++-6.q16-5v5 (>= 8:6.8.9.9-7) but it is not going to be installed
Recommends: libimage-magick-perl but it is not going to be installed
I naviely tried to simply install libmagick++, but here's the result:
Note, selecting 'libmagick++-dev' for regex 'libmagick+'
Note, selecting 'libmagick++-6.q16-5' for regex 'libmagick+'
Note, selecting 'libmagick++-6.q16-6' for regex 'libmagick+'
Note, selecting 'libmagick++-6.q16-7' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16' for regex 'libmagick+'
Note, selecting 'libmagick++-6.defaultquantum-dev' for regex 'libmagick+'
Note, selecting 'libmagickwand-6.q16-2' for regex 'libmagick+'
Note, selecting 'libmagickwand-6.q16-3' for regex 'libmagick+'
Note, selecting 'libmagickwand-6-headers' for regex 'libmagick+'
Note, selecting 'libmagick++6-dev' for regex 'libmagick+'
Note, selecting 'libmagick9-dev' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16-1-extra' for regex 'libmagick+'
Note, selecting 'libmagick++-6-headers' for regex 'libmagick+'
Note, selecting 'graphicsmagick-libmagick-dev-compat' for regex 'libmagick+'
Note, selecting 'libmagickwand5' for regex 'libmagick+'
Note, selecting 'libmagickcore-extra' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.defaultquantum-dev' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16-2-extra' for regex 'libmagick+'
Note, selecting 'libmagickcore-6-headers' for regex 'libmagick+'
Note, selecting 'libmagickcore-6-arch-config' for regex 'libmagick+'
Note, selecting 'libmagickwand-6.defaultquantum-dev' for regex 'libmagick+'
Note, selecting 'libmagickwand-6.q16-dev' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16-2' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16-3' for regex 'libmagick+'
Note, selecting 'libmagick++9-dev' for regex 'libmagick+'
Note, selecting 'libmagickwand-dev' for regex 'libmagick+'
Note, selecting 'libmagick++-6.q16-5v5' for regex 'libmagick+'
Note, selecting 'libmagick++-6.q16-dev' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16-3-extra' for regex 'libmagick+'
Note, selecting 'libmagick-dev' for regex 'libmagick+'
Note, selecting 'libmagickcore-6.q16-dev' for regex 'libmagick+'
Note, selecting 'libmagick6-dev' for regex 'libmagick+'
Note, selecting 'libmagickcore-dev' for regex 'libmagick+'
Note, selecting 'libmagick++-6.q16-dev' instead of 'libmagick++-6.defaultquantum-dev'
Note, selecting 'libmagickcore-6.q16-dev' instead of 'libmagickcore-6.defaultquantum-dev'
Note, selecting 'libmagickwand-6.q16-dev' instead of 'libmagickwand-6.defaultquantum-dev'
Note, selecting 'graphicsmagick-libmagick-dev-compat' instead of 'libmagick-dev'
libmagick++-6-headers is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagick++-6-headers set to manually installed.
libmagick++-6.q16-dev is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagick++-6.q16-dev set to manually installed.
libmagickcore-6.q16-3 is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickcore-6.q16-3 set to manually installed.
libmagickwand-6-headers is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickwand-6-headers set to manually installed.
libmagickcore-6-arch-config is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickcore-6-arch-config set to manually installed.
libmagickwand-6.q16-dev is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickwand-6.q16-dev set to manually installed.
libmagick++-6.q16-7 is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagick++-6.q16-7 set to manually installed.
libmagickcore-6.q16-3-extra is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickcore-6.q16-3-extra set to manually installed.
libmagickwand-6.q16-3 is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickwand-6.q16-3 set to manually installed.
libmagickcore-6.q16-dev is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickcore-6.q16-dev set to manually installed.
libmagickcore-6-headers is already the newest version (8:6.9.7.4+dfsg-16xenial0).
libmagickcore-6-headers set to manually installed.
libmagick++-dev is already the newest version (8:6.9.7.4+dfsg-16xenial0).
graphicsmagick-libmagick-dev-compat : Conflicts: libmagick++-dev
Conflicts: libmagick++-dev:i386
Conflicts: libmagickcore-dev but 8:6.8.9.9-7ubuntu5.15 is to be installed
Conflicts: libmagickcore-dev:i386
imagemagick-6-common : Breaks: libmagickcore-6.q16-2 (< 8:6.9.6.2+dfsg-3~) but 8:6.8.9.9-7ubuntu5.15 is to be installed
libmagickcore-6.q16-2 : Depends: imagemagick-common (= 8:6.8.9.9-7ubuntu5.15)
libmagickwand-6.q16-2 : Depends: imagemagick-common (= 8:6.8.9.9-7ubuntu5.15)
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I also tried installing Inkscape from the PPA with the same results. Any and all pointers would be appreciated. None of the similar questions I found had this issue.
Many thanks!
UPDATE:
as suggested by N0rbert, I've run sudo apt-get update and retried sudo apt-get install inkscape, but the results are the same.
Additionally:
apt-cache policy inkscape libmagick++-6.q16-5v5
inkscape:
Installed: (none)
Candidate: 0.91-7ubuntu2
Version table:
0.91-7ubuntu2 500
500 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages
libmagick++-6.q16-5v5:
Installed: (none)
Candidate: 8:6.8.9.9-7ubuntu5.15
Version table:
8:6.8.9.9-7ubuntu5.15 500
500 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu xenial-security/main amd64 Packages
8:6.8.9.9-7ubuntu5 500
grep -ir "^deb" /etc/apt/ --include=*.list
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial main restricted
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial universe
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial-updates universe
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial multiverse
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial-updates multiverse
/etc/apt/sources.list:deb http://archive.canonical.com/ubuntu xenial partner
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial-security main restricted
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial-security universe
/etc/apt/sources.list:deb http://archive.ubuntu.com/ubuntu xenial-security multiverse
/etc/apt/sources.list:deb http://archive.canonical.com/ xenial partner
/etc/apt/sources.list:deb http://qgis.org/debian xenial main
/etc/apt/sources.list:deb https://cloud.r-project.org//bin/linux/ubuntu xenial/
/etc/apt/sources.list:deb http://download.ebz.epson.net/dsc/op/stable/debian/ lsb3.2 main
/etc/apt/sources.list:deb https://cloud.r-project.org/bin/linux/ubuntu xenial-cran35/
/etc/apt/sources.list.d/dropbox.list:deb [arch=i386,amd64] http://linux.dropbox.com/ubuntu xenial main
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list:deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
/etc/apt/sources.list.d/apandada1-ubuntu-brightness-controller-xenial.list:deb http://ppa.launchpad.net/apandada1/brightness-controller/ubuntu xenial main
/etc/apt/sources.list.d/libreoffice-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/libreoffice/ppa/ubuntu xenial main
/etc/apt/sources.list.d/mendeleydesktop.list:deb https://desktop-download.mendeley.com/download/apt stable main
/etc/apt/sources.list.d/graphics-drivers-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial main
/etc/apt/sources.list.d/danielrichter2007-ubuntu-grub-customizer-xenial.list:deb http://ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu xenial main
/etc/apt/sources.list.d/otto-kesselgulasch-ubuntu-gimp-xenial.list:deb http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu xenial main
/etc/apt/sources.list.d/spotify.list:deb http://repository.spotify.com stable non-free
Please let me know if any more info is useful!
