I have a laravel app on a ubuntu 20.04 server. How do I enable it to automatically apply only security updates?
does the following only install security updates or other updates:
sudo apt install unattended-upgrades
my sudo nano /etc/apt/apt.conf.d/50unattended-upgrades is as follows:
Unattended-Upgrade::Allowed-Origins {
    "${distro_id}:${distro_codename}";
    "${distro_id}:${distro_codename}-security";
    // Extended Security Maintenance; doesn't necessarily exist for
    // every release and this system may not have it installed, but if
    // available, the policy for updates is such that unattended-upgrades
    // should also install from here by default.
    "${distro_id}ESMApps:${distro_codename}-apps-security";
    "${distro_id}ESM:${distro_codename}-infra-security";
   //"${distro_id}:${distro_codename}-updates";
   //"${distro_id}:${distro_codename}-proposed";
   //"${distro_id}:${distro_codename}-backports";
Do I need to do anything else?
adam78
  • 131
Go to Software and Updates and enable Livepatch. Canonical Livepatch helps keep your system secure by applying security updates that don't require a restart.
Or you can use the terminal for security updates using the command:
sudo unattended-upgrade
Freax
  • 155
My personal preference is the following: The reconfigure brings up a text ui to confirm and then you are done.
sudo apt-get install unattended-upgrades sudo dpkg-reconfigure unattended-upgrades
kkron
  • 151
