Last night I tried to upgrade from Ubuntu 18.04.5 to 20.04 by using the command
sudo do-release-upgrade.
When it gave me the prompt to start downloading the new packages, and gave me the warning that once downloaded, you couldn't stop it, I hit details to check the packages that would be deleted. Once on the details screen, I didn't know how to back out to confirm the download, so I ctrl+c out, and typed sudo do-release-upgrade again. But it gave me an error saying that I have to update all current packages before doing the release upgrade. I ran
sudo apt update
sudo apt upgrade
and it showed thousands of packages that needed to be upgraded. Assuming that's what would do the upgrade to 20.04, I confirmed the upgrade, and it started downloading and upgrading the packages.
Halfway through, I got an error, and it stopped upgrading.
I retried doing
sudo apt upgrade
but the same error would pop up.
After a few minutes, i got automatically logged out while trying to open Software & Updates and I couldn't log back in, as it would kick me back to the login screen.
Now I started googling the problem and followed this guide. When doing
sudo dpkg --configure -a
this shows up:
pkg: dependency problems prevent configuration of libgles-dev:amd64: libgles-dev:amd64 depends on libgl-dev; however: Package libgl-dev:amd64 is not installed.dpkg: error processing package libgles-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libglvnd-dev:amd64: libglvnd-dev:amd64 depends on libgl-dev (>= 1.3.0-1); however: Package libgl-dev:amd64 is not installed. libglvnd-dev:amd64 depends on libgles-dev (>= 1.3.0-1); however: Package libgles-dev:amd64 is not configured yet. libglvnd-dev:amd64 depends on libglx-dev (>= 1.3.0-1); however: Package libglx-dev:amd64 is not installed.
dpkg: error processing package libglvnd-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libgl1-mesa-dev:amd64: libgl1-mesa-dev:amd64 depends on libgl-dev; however: Package libgl-dev:amd64 is not installed. libgl1-mesa-dev:amd64 depends on libglvnd-dev; however: Package libglvnd-dev:amd64 is not configured yet.
dpkg: error processing package libgl1-mesa-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libegl-dev:amd64: libegl-dev:amd64 depends on libgl-dev; however: Package libgl-dev:amd64 is not installed.
dpkg: error processing package libegl-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libglvnd-core-dev:amd64: libglvnd-core-dev:amd64 depends on libglvnd-dev; however: Package libglvnd-dev:amd64 is not configured yet.
dpkg: error processing package libglvnd-core-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libglu1-mesa-dev:amd64: libglu1-mesa-dev:amd64 depends on libgl1-mesa-dev | libgl-dev; however: Package libgl1-mesa-dev:amd64 is not configured yet. Package libgl-dev:amd64 is not installed.
dpkg: error processing package libglu1-mesa-dev:amd64 (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: libgles-dev:amd64 libglvnd-dev:amd64 libgl1-mesa-dev:amd64 libegl-dev:amd64 libglvnd-core-dev:amd64 libglu1-mesa-dev:amd64
but it fixed the login issue, so I can now use the computer again. But now I still have the problem of not being able to upgrade to 20.04. And it seems that my dependencies are broken.
When trying
> sudo apt install -f
I get
Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: libcbor0.6 libdrm-dev libffi7:i386 libfido2-1 libglvnd-core-dev libpcre3:i386 libx11-xcb-dev libxcb-dri2-0-dev libxcb-dri3-dev libxcb-glx0-dev libxcb-present-dev libxcb-randr0-dev libxcb-render0-dev libxcb-shape0-dev libxcb-sync-dev libxcb-xfixes0-dev libxdamage-dev libxext-dev libxfixes-dev libxshmfence-dev libxxf86vm-dev mesa-common-dev x11proto-damage-dev x11proto-fixes-dev x11proto-xext-dev x11proto-xf86vidmode-dev Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: libgl-dev libglx-dev The following NEW packages will be installed: libgl-dev libglx-dev 0 upgraded, 2 newly installed, 0 to remove and 1689 not upgraded. 6 not fully installed or removed. Need to get 0 B/112 kB of archives. After this operation, 1.480 kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 246661 files and directories currently installed.) Preparing to unpack .../libglx-dev_1.3.1-1_amd64.deb ... Unpacking libglx-dev:amd64 (1.3.1-1) ... dpkg: error processing archive /var/cache/apt/archives/libglx-dev_1.3.1-1_amd64.deb (--unpack): trying to overwrite '/usr/include/GL/glx.h', which is also in package mesa-common-dev:amd64 20.0. 8-0ubuntu1~18.04.1 Preparing to unpack .../libgl-dev_1.3.1-1_amd64.deb ... Unpacking libgl-dev:amd64 (1.3.1-1) ... dpkg: error processing archive /var/cache/apt/archives/libgl-dev_1.3.1-1_amd64.deb (--unpack): trying to overwrite '/usr/include/GL/gl.h', which is also in package mesa-common-dev:amd64 20.0.8 -0ubuntu1~18.04.1 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/libglx-dev_1.3.1-1_amd64.deb /var/cache/apt/archives/libgl-dev_1.3.1-1_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
I feel that it's worth mentioning that the package lists seem to be the focal ones and not bionic beaver. See sudo apt update:
Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease Hit:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease Hit:3 http://security.ubuntu.com/ubuntu xenial-security InRelease Hit:4 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease Hit:5 http://it.archive.ubuntu.com/ubuntu xenial-updates InRelease Hit:6 http://us.archive.ubuntu.com/ubuntu focal-security InRelease Reading package lists... Done Building dependency tree Reading state information... Done 1689 packages can be upgraded. Run 'apt list --upgradable' to see them.
I would appreciate any help on trying to fix this issue. I'm thinking of reverting the package lists to the bionic beaver ones but I don't know how to do that.
Thank you in advance.
