If I'm using Ubuntu 18.04 Bionic Beaver, but I configure groovy (20.10) in the apt source, will I have problems installing the software? If a certain software is installed normally, will there be any risks in the future?
If I understand what you've described (you didn't say what repositories, nor if you put any package restrictions in place), it'll cause your bionic system to upgrade to groovy and likely break, as that's not a tested/supported upgrade path, and misses the protections provided by correct release-upgrade tools. Your system will also EOL when groovy does, ie. also no longer be a LTS release. It's unwise unless you consider the consequences (research on the packages to be installed, what parts of your software stack will be changed impacting what else you have installed etc)
reworded clarification
Apt & package tools look for packages that can be updated... and upgrade any bionic packages that are found in groovy sources (ie. nearly every package you have installed) which is why I said you won't be running bionic any longer. You'll be switching to groovy and likely break your system. Even if you switch sources back to bionic, you won't be running bionic anymore, but instead a frankensystem
If you do the change, sudo apt update and then try and install only a single package, that may not work either, it'll depend on the package.
If the package is for example wallpapers for groovy, it'll have ~no depends rules that will pull in other groovy packages. However most packages will have depends rules which cause other packages to be installed, those packages likewise have their own depends rules etc... thus a single package usually pulls in others, the others pulling in more. (snowball effect)
For the groovy wallpaper package (eg. https://packages.ubuntu.com/groovy/ubuntu-wallpapers shows one focal depends (which really is because groovy hasn't had it's wallpapers packaged yet so the quick work-around fix is just to use focal's.. an easy example). Most packages however aren't that simple which is the problem.
this really is just slightly edited comments
- 33,561
