Since I installed Ubuntu 10.04 on my PC, I have eclipse crashing every hour or more without apparent action. In the logs, I see that the cause is related to JAVA :
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f95f32ce9c0, pid=2382, tid=140280562099984
# JRE version: 6.0_18-b18
# Java VM: OpenJDK 64-Bit Server VM (16.0-b13 mixed mode linux-amd64 )
# Derivative: IcedTea6 1.8.2
# Distribution: Ubuntu 10.04.1 LTS, package 6b18-1.8.2-4ubuntu2
# Problematic frame:
# V  [libjvm.so+0x5309c0]
# An error report file with more information is saved as:
# /home/elapouya/perso/projects/django/rsame/hs_err_pid2382.log
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
#   https://bugs.launchpad.net/ubuntu/+source/openjdk-6/
www.eclipse.org knows this bug and it is RECOMMENDED to use 1.6.0.10 or more, or go jdk 1.5 I installed the latest JVM official but still crashes. I 6.0_18-b18 (I do not know if this is 1.6.0.10 ...) So I installed an older version: 1.5.0_19, but I still have random crashes:
# An unexpected error has been detected by HotSpot Virtual Machine:
#  SIGSEGV (0xb) at pc=0x00007fc833c91dfe, pid=8630, tid=140496587896592
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_19-b02 mixed mode)
# V  [libjvm.so+0x5b1dfe]
# An error report file with more information is saved as hs_err_pid8630.log
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
I did an apt-get upgrade to be up-to-date, but it continues to crash:
What do you recommend?
Jorge Castro
  • 73,717
Eric
  • 791
I would switch to the 32-bit jre/jdk and file a bug report...once they sort it out back to 64-bit. Alternately, you could try the binary installer from Sun directly instead of the openjdk, but this may mess with your dependencies and you'll have to set some environment variables in .profile or .bashrc
RobotHumans
  • 30,112
