I tried upgrading once more to 12.04 after it went live. I had tried both Beta 1 and Beta 2. The problem is that now I'm getting sporadic network connectivity. My computer is hooked up straight to my modem/router combo -- it is hardwired, so wireless can be thrown out of the question. My other devices (Computers, Phone, Tablets, etc) all are able to connect correctly and this is only happening with 12.04. 11.10 works like a charm.
Output for ifconfig -a is as follows:
Link encap:Ethernet  HWaddr 00:1e:2a:b2:4f:28
      inet addr:10.0.0.3  Bcast:10.0.0.255  Mask:255.255.255.0
      inet6 addr: fe80::21e:2aff:feb2:4f28/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:4093 errors:0 dropped:0 overruns:0 frame:0
      TX packets:3531 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:3767248 (3.7 MB)  TX bytes:555829 (555.8 KB)
      Interrupt:22 Base address:0xec00
Output for ethtool -S eth2 is as follows:
 NIC statistics:
 tx_packets: 870
 rx_packets: 854
 tx_errors: 3
 rx_errors: 1
 rx_missed: 0
 align_errors: 1385
 tx_single_collisions: 0
 tx_multi_collisions: 0
 unicast: 683
 broadcast: 57
 multicast: 114
 tx_aborted: 0
 tx_underrun: 0$
Output for netstat -i is as follows:
Kernel Interface table
Iface   MTU Met   RX-OK RX-ERR RX-DRP RX-OVR    TX-OK TX-ERR TX-DRP TX-OVR Flg
eth0       1500 0         0      0      0 0             0      0      0      0 BMU
eth1       1500 0         0      0      0 0             0      0      0      0 BMU
eth2       1500 0       854      0      0 0           870      0      0      0 BMRU
lo        16436 0       215      0      0 0           215      0      0      0 LRU
Again, this is sporadic. It sometimes doesn't do this on startup, and sometimes does. It will work fine for 10 mins or so, then not work for hours, then work for hours. I'm not a network guy by any means so most of what I just posted is foreign to me - anyone have any suggestions as to what to check and what the RX-ERR and TX-ERR are?
Thanks!
SQLSavant
  • 283
5 Answers5
I was able to fix this issue by turning off automatic detection of my NIC and manually adding the Gateway, Address, and Mask IP's pointing directly to my router.
I used this answer to a previous question - No internet connection, ifconfig shows errors
SQLSavant
  • 283
This answer resolved it for me:
network manager says "device not managed"
boyang
I had the same problem. I turned the wireless LAN OFF and then turned ON. This seems to have resolved the issue on my side.
Use System settings => network => Wireless => ON/OFF
I have not seen the Internet connection issues since 24 hrs.
I hope this helps for others as well.
Shiva C
This only works if you have NOT upgraded already to 12.04. It is not an option for those of us who made the mistake of actually loading the full upgrade, but thank you.
This happened for me also. I did the following steps and everything was alright.
  1. Go to the top right of the screen.
  2. Choose "Software up to date" from the menu
  3. Do a partial upgrade
Ref: http://blog.sbw.be/2012/04/28/upgrading-from-ubuntu-11-10-to-12-04lts/
Hari
(temp) SOLVED: I had the same issue. But because I came from upgrading instead of fresh installing. In the boot options, I selected the previous boot option with different kernel. My option kernel is "3.0.0.17-generic-pae" and after login, it works! Seems to me that the kernel in this new upgrade still has some bugs to fix!
