I installed Ubuntu 20.04 on my SSD alongside Windows 10, but I can't boot Ubuntu 20.04. It always boots Windows. I ran Boot-Repair, but it didn't work. http://paste.ubuntu.com/p/WvMfFgJvXN/ Here is my Boot Repair Summary.
============================= Boot Repair Summary ==============================
Error code 12 mount -r /dev/sda3 /mnt/boot-sav/sda3
mount -r /dev/sda3 : Error code 12 Error code 12 mount -r /dev/sda3 /mnt/boot-sav/sda3
error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map. error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda2. Check your device.map. error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda3. Check your device.map. Windows is hibernated, refused to mount. Falling back to read-only mount because the NTFS partition is in an unsafe state. Please resume and shutdown Windows fully (no hibernation or fast restarting.) Could not mount read-write, trying read-only Failed to read last sector (1952491518): Invalid argument HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid). Failed to mount '/dev/sda3': Invalid argument The device '/dev/sda3' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around? Failed to read last sector (1952491518): Invalid argument HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid). Failed to mount '/dev/sda3': Invalid argument The device '/dev/sda3' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around? error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda3. Check your device.map. Failed to read last sector (1952491518): Invalid argument HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid). Failed to mount '/dev/sda3': Invalid argument The device '/dev/sda3' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around? Failed to read last sector (1952491518): Invalid argument HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid). Failed to mount '/dev/sda3': Invalid argument The device '/dev/sda3' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around? /usr/share/boot-sav/bs-cmd_terminal.sh: line 177: warning: command substitution: ignored null byte in input
Advices: _______________________________________________________________________ SFS detected. You may want to retry after converting Windows dynamic partitioning (SFS partitions) to a basic disk. This can be performed via tools such as TestDisk or EASEUS-Partition-Master / MiniTool-Partition-Wizard. Are you sure you want to continue anyway? yes
Recommended repair: ____________________________________________________________
The default repair of the Boot-Repair utility will reinstall the grub-efi-amd64-signed of nvme0n1p4, using the following options: nvme0n1p1/boot/efi, Additional repair will be performed: unhide-bootmenu-10s win-legacy-basic-fix use-standard-efi-file
/boot/efi added in nvme0n1p4/fstab Quantity of real Windows: 2 Mount nvme0n1p1 on /mnt/boot-sav/nvme0n1p4/boot/efi
=============== Reinstall the grub-efi-amd64-signed of nvme0n1p4 ===============
grub-install --version grub-install (GRUB) 2.04-1ubuntu26.2
efibootmgr -v from chroot before grub install BootCurrent: 0009 Timeout: 0 seconds BootOrder: 0009,0000,0001,0008,0006,0007 Boot0000* Windows Boot Manager HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(EFIMICROSOFTBOOTBOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a................ Boot0001* ubuntu HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(EFIUBUNTUSHIMX64.EFI) Boot0006* UEFI: IP4 Qualcomm Atheros PCIe Network Controller PciRoot(0x0)/Pci(0x1c,0x3)/Pci(0x0,0x0)/MAC(4ccc6a82b6c9,0)/IPv4(0.0.0.00.0.0.0,0,0)..BO Boot0007* UEFI: IP6 Qualcomm Atheros PCIe Network Controller PciRoot(0x0)/Pci(0x1c,0x3)/Pci(0x0,0x0)/MAC(4ccc6a82b6c9,0)/IPv6([::]:<->[::]:,0,0)..BO Boot0008* ubuntu HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(EFIUBUNTUGRUBX64.EFI)..BO Boot0009* UEFI: SanDisk, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(21,0)/HD(1,GPT,2cfd3007-5d85-481d-9b18-aa2ade562ae9,0x800,0x1ca37df)..BO
uname -r 5.4.0-42-generic
grub-install --efi-directory=/boot/efi --target=x86_64-efi --uefi-secure-boot Installing for x86_64-efi platform. Installation finished. No error reported. df /dev/nvme0n1p1 mv /mnt/boot-sav/nvme0n1p4/boot/efi/EFI/Boot/bootx64.efi /mnt/boot-sav/nvme0n1p4/boot/efi/EFI/Boot/bkpbootx64.efi cp /mnt/boot-sav/nvme0n1p4/boot/efi/EFI/ubuntu/shimx64.efi /mnt/boot-sav/nvme0n1p4/boot/efi/EFI/Boot/bootx64.efi cp /mnt/boot-sav/nvme0n1p4/boot/efi/EFI/ubuntu/grubx64.efi /mnt/boot-sav/nvme0n1p4/boot/efi/EFI/Boot/
efibootmgr -v from chroot after grub install BootCurrent: 0009 Timeout: 0 seconds BootOrder: 0001,0009,0000,0006,0007 Boot0000* Windows Boot Manager HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(EFIMICROSOFTBOOTBOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a................ Boot0001* ubuntu HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(EFIubuntushimx64.efi) Boot0006* UEFI: IP4 Qualcomm Atheros PCIe Network Controller PciRoot(0x0)/Pci(0x1c,0x3)/Pci(0x0,0x0)/MAC(4ccc6a82b6c9,0)/IPv4(0.0.0.00.0.0.0,0,0)..BO Boot0007* UEFI: IP6 Qualcomm Atheros PCIe Network Controller PciRoot(0x0)/Pci(0x1c,0x3)/Pci(0x0,0x0)/MAC(4ccc6a82b6c9,0)/IPv6([::]:<->[::]:,0,0)..BO Boot0009* UEFI: SanDisk, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(21,0)/HD(1,GPT,2cfd3007-5d85-481d-9b18-aa2ade562ae9,0x800,0x1ca37df)..BO
chroot /mnt/boot-sav/nvme0n1p4 update-grub Sourcing file /etc/default/grub' Sourcing file/etc/default/grub.d/init-select.cfg' Generating grub configuration file ... Found linux image: /boot/vmlinuz-5.4.0-42-generic Found initrd image: /boot/initrd.img-5.4.0-42-generic error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map. error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda2. Check your device.map. error: invalid volume. grub-probe: error: cannot find a GRUB drive for /dev/sda3. Check your device.map. Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi Adding boot menu entry for UEFI Firmware Settings Windows is hibernated, refused to mount. Falling back to read-only mount because the NTFS partition is in an unsafe state. Please resume and shutdown Windows fully (no hibernation or fast restarting.) Could not mount read-write, trying read-only Failed to read last sector (1952491518): Invalid argument HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid). Failed to mount '/dev/sda3': Invalid argument The device '/dev/sda3' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around? Failed to read last sector (1952491518): Invalid argument HINTS: Either the volume is a RAID/LDM but it wasn't setup yet, or it was not setup correctly (e.g. by not using mdadm --build ...), or a wrong device is tried to be mounted, or the partition table is corrupt (partition is smaller than NTFS), or the NTFS boot sector is corrupt (NTFS size is not valid). Failed to mount '/dev/sda3': Invalid argument The device '/dev/sda3' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
Unhide GRUB boot menu in nvme0n1p4/boot/grub/grub.cfg
An error occurred during the repair.
You can now reboot your computer.
Please do not forget to make your UEFI firmware boot on the Ubuntu 20.04.1 LTS entry (nvme0n1p1/EFI/ubuntu/shimx64.efi file) ! If your computer reboots directly into Windows, try to change the boot order in your UEFI firmware.
If your UEFI firmware does not allow to change the boot order, change the default boot entry of the Windows bootloader. For example you can boot into Windows, then type the following command in an admin command prompt: bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi
============================ Boot Info After Repair ============================
=> No boot loader is installed in the MBR of /dev/nvme0n1. => Windows 7/8/2012 is installed in the MBR of /dev/sda. => No known boot loader is installed in the MBR of /dev/sdb.
nvme0n1p1: _____________________________________________________________________
File system:       vfat
Boot sector type:  Windows 8/2012: FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /efi/Boot/bkpbootx64.efi /efi/Boot/bootx64.efi
                   /efi/Boot/fbx64.efi /efi/Boot/grubx64.efi
                   /efi/Boot/mmx64.efi /efi/ubuntu/grubx64.efi
                   /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
                   /efi/ubuntu/grub.cfg /efi/Microsoft/Boot/bootmgfw.efi
                   /efi/Microsoft/Boot/bootmgr.efi
                   /efi/Microsoft/Boot/memtest.efi
nvme0n1p2: _____________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
nvme0n1p3: _____________________________________________________________________
File system:       ntfs
Boot sector type:  Windows 8/2012: NTFS
Operating System:  Windows 10
Boot files:        /Windows/System32/winload.exe
nvme0n1p4: _____________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 20.04.1 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
sda1: __________________________________________________________________________
File system:       ntfs
Boot sector info:  According to the info in the boot sector, sda1 starts
                   at sector 2048. But according to the info from fdisk,
                   sda1 starts at sector 63. According to the info in the
                   boot sector, sda1 has 1023999 sectors, but according
                   to the info from fdisk, it has 1953523056 sectors.
Operating System:
Boot files:        /bootmgr /Boot/BCD
sdb1: __________________________________________________________________________
File system:       vfat
Operating System:
Boot files:        /boot/grub/grub.cfg /syslinux.cfg
                   /efi/BOOT/grubx64.efi /efi/BOOT/mmx64.efi
================================ 3 OS detected =================================
OS#1: Ubuntu 20.04.1 LTS on nvme0n1p4 OS#2: Windows 10 on nvme0n1p3 OS#3: Windows 8 or 10 on sda2
============================ Architecture/Host Info ============================
CPU architecture: 64-bit Live-session OS is Ubuntu 64-bit (Ubuntu 20.04.1 LTS, focal, x86_64)
===================================== UEFI =====================================
BIOS is EFI-compatible, and is setup in EFI-mode for this live-session. SecureBoot disabled.
efibootmgr -v BootCurrent: 0009 Timeout: 0 seconds BootOrder: 0009,0000,0001,0008,0006,0007 Boot0000* Windows Boot Manager HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a................ Boot0001* ubuntu HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(\EFI\UBUNTU\SHIMX64.EFI) Boot0006* UEFI: IP4 Qualcomm Atheros PCIe Network Controller PciRoot(0x0)/Pci(0x1c,0x3)/Pci(0x0,0x0)/MAC(4ccc6a82b6c9,0)/IPv4(0.0.0.00.0.0.0,0,0)..BO Boot0007* UEFI: IP6 Qualcomm Atheros PCIe Network Controller PciRoot(0x0)/Pci(0x1c,0x3)/Pci(0x0,0x0)/MAC(4ccc6a82b6c9,0)/IPv6([::]:<->[::]:,0,0)..BO Boot0008* ubuntu HD(1,GPT,330dcb06-e3af-48dd-ae94-0b3b45388b47,0x800,0x32000)/File(\EFI\UBUNTU\GRUBX64.EFI)..BO Boot0009* UEFI: SanDisk, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(21,0)/HD(1,GPT,2cfd3007-5d85-481d-9b18-aa2ade562ae9,0x800,0x1ca37df)..BO
f7a57b08bc7c1c85417ae4cea582d1d4 nvme0n1p1/Boot/bootx64.efi bed45d1c9554cea09924d3814cb7c446 nvme0n1p1/Boot/fbx64.efi 4487628005555bfd4a4c0a47211e0700 nvme0n1p1/Boot/mmx64.efi 1476c8ed1ce8271aab2fbe89d534cfa4 nvme0n1p1/ubuntu/grubx64.efi 4487628005555bfd4a4c0a47211e0700 nvme0n1p1/ubuntu/mmx64.efi f7a57b08bc7c1c85417ae4cea582d1d4 nvme0n1p1/ubuntu/shimx64.efi 4f0248591a11d5432380ba65f683879b nvme0n1p1/Microsoft/Boot/bootmgfw.efi 1feb5f9427494e6f598603caa3af7d99 nvme0n1p1/Microsoft/Boot/bootmgr.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, 2048 sectors * 512 bytes sda : notGPT, no-BIOSboot, has-noESP, not-usb, not-mmc, has-os, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p1 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far nvme0n1p3 : is-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios nvme0n1p4 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios sda1 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda2 : is-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda3 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
Partitions info (2/3): _________________________________________________________
nvme0n1p1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot nvme0n1p3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot nvme0n1p4 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, bootmgr, is-winboot sda2 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, bootmgr, is-winboot sda3 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
nvme0n1p1 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1 nvme0n1p3 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1 nvme0n1p4 : not-sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, nvme0n1 sda1 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda2 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda3 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 447.13 GiB, 480103981056 bytes, 937703088 sectors Disk identifier: 613A52E2-8D70-4415-8335-5F9CB61D7D07 Start End Sectors Size Type nvme0n1p1 2048 206847 204800 100M EFI System nvme0n1p2 206848 239615 32768 16M Microsoft reserved nvme0n1p3 239616 732901375 732661760 349.4G Microsoft basic data nvme0n1p4 732901376 937701375 204800000 97.7G Linux filesystem Disk sda: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors Disk identifier: 0x788d8f45 Boot Start End Sectors Size Id Type sda1 63 1953523119 1953523057 931.5G 42 SFS Disk sdb: 14.33 GiB, 15376318464 bytes, 30031872 sectors Disk identifier: A9A4A12F-51C0-4EFB-BCE5-3B5CFDA24058 Start End Sectors Size Type sdb1 2048 30031838 30029791 14.3G Microsoft basic data
parted -lm (filtered): _________________________________________________________
sda:1000GB:scsi:512:4096:msdos:ATA HGST HTS721010A9:; 1:32.3kB:1000GB:1000GB:fat32::; sdb:15.4GB:scsi:512:512:gpt:SanDisk Ultra USB 3.0:; 1:1049kB:15.4GB:15.4GB:fat32:Main Data Partition:msftdata; nvme0n1:480GB:nvme:512:512:gpt:Force MP510:; 1:1049kB:106MB:105MB:fat32:EFI system partition:boot, esp; 2:106MB:123MB:16.8MB::Microsoft reserved partition:msftres; 3:123MB:375GB:375GB:ntfs:Basic data partition:msftdata; 4:375GB:480GB:105GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 ntfs FAA6874CA68707F9 Sistem Ayrıldı ├─sda2 ntfs DC9E98BD9E98919E
└─sda3 ntfs 9C124BEE124BCC48 Yeni Birim
sdb
└─sdb1 vfat 1277-BBC4 2cfd3007-5d85-481d-9b18-aa2ade562ae9 UBUNTU 20_0 Main Data Partition nvme0n1
├─nvme0n1p1 vfat 6A11-A2DA 330dcb06-e3af-48dd-ae94-0b3b45388b47 EFI system partition ├─nvme0n1p2 7ca0554f-884e-49af-b239-53f770bd3405 Microsoft reserved partition ├─nvme0n1p3 ntfs 7A6E18226E17D5AB 5ee01c00-00a6-4af0-a66b-182144791c7a Basic data partition └─nvme0n1p4 ext4 84acdf81-737d-4731-81af-818c5f1807e8 18000522-24f4-43b0-9fc2-9bc2914e6541
df (filtered): _________________________________________________________________
       Avail Use% Mounted on
nvme0n1p1 60.5M 37% /mnt/boot-sav/nvme0n1p1 nvme0n1p3 312G 11% /mnt/boot-sav/nvme0n1p3 nvme0n1p4 84.2G 7% /mnt/boot-sav/nvme0n1p4 sda1 469M 6% /mnt/boot-sav/sda1 sda2 18.7G 95% /mnt/boot-sav/sda2 sdb1 11.7G 18% /cdrom
Mount options: __________________________________________________________________
nvme0n1p1 rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro nvme0n1p3 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 nvme0n1p4 rw,relatime sda1 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 sda2 ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096 sdb1 ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
=================== nvme0n1p1/efi/ubuntu/grub.cfg (filtered) ===================
search.fs_uuid 84acdf81-737d-4731-81af-818c5f1807e8 root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg
=================== nvme0n1p4/boot/grub/grub.cfg (filtered) ====================
Ubuntu 84acdf81-737d-4731-81af-818c5f1807e8 Ubuntu, with Linux 5.4.0-42-generic 84acdf81-737d-4731-81af-818c5f1807e8 Windows Boot Manager (on nvme0n1p1) osprober-efi-6A11-A2DA
END /etc/grub.d/30_os-prober
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
======================== nvme0n1p4/etc/fstab (filtered) ========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/nvme0n1p4 during installation
UUID=84acdf81-737d-4731-81af-818c5f1807e8 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/nvme0n1p1 during installation
/swapfile none swap sw 0 0 UUID=6A11-A2DA /boot/efi vfat defaults 0 1
==================== nvme0n1p4/etc/default/grub (filtered) =====================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
================= nvme0n1p4: Location of files loaded by Grub ==================
       GiB - GB             File                                 Fragment(s)
349.474613190 = 375.245508608 boot/grub/grub.cfg 1 353.969844818 = 380.072226816 boot/vmlinuz 1 353.969844818 = 380.072226816 boot/vmlinuz-5.4.0-42-generic 1 436.067604065 = 468.224024576 boot/initrd.img 3 436.067604065 = 468.224024576 boot/initrd.img-5.4.0-42-generic 3 436.067604065 = 468.224024576 boot/initrd.img.old 3
=================== nvme0n1p4: ls -l /etc/grub.d/ (filtered) ===================
-rwxr-xr-x 1 root root 17123 Jul 31 00:34 10_linux -rwxr-xr-x 1 root root 42128 Jul 31 00:34 10_linux_zfs -rwxr-xr-x 1 root root 12894 Jul 31 00:34 20_linux_xen -rwxr-xr-x 1 root root 12059 Jul 31 00:34 30_os-prober -rwxr-xr-x 1 root root 1424 Jul 31 00:34 30_uefi-firmware -rwxr-xr-x 1 root root 214 Jul 31 00:34 40_custom -rwxr-xr-x 1 root root 216 Jul 31 00:34 41_custom
====================== sdb1/boot/grub/grub.cfg (filtered) ======================
Ubuntu Ubuntu (safe graphics) OEM install (for manufacturers) Boot from next volume UEFI Firmware Settings
========================= sdb1/syslinux.cfg (filtered) =========================
DEFAULT loadconfig
LABEL loadconfig CONFIG /isolinux/isolinux.cfg APPEND /isolinux/
==================== sdb1: Location of files loaded by Grub ====================
        ?? = ??             boot/grub/grub.cfg                             1
================== sdb1: Location of files loaded by Syslinux ==================
        ?? = ??             syslinux.cfg                                   1
======================== Unknown MBRs/Boot Sectors/etc =========================
Unknown MBR on /dev/sdb
karel
  • 122,292
  • 133
  • 301
  • 332
I solved it while checking If I did something wrong on this thread (askubuntu.com/questions/221835/…) I needed to configure EFI partition for windows
