I have placed some large folders on a separate disk, in a single partition, but I want them to show up in my file system as if they were in my root partition. In fstab I mount the separate disk on /extern. The large folders are then in the file system as /extern/videos, /extern/music, but I would rather see just /videos, /music. I've read that, once upon a time, this was possible by mounting /extern with a line in fstab like
UUID=bb906568-0651-4eca-a111-dcab4d1a0bf1 /extern ext4 defaults,x-gvfs-hide 0 2
I then used "bind" to mount /videos and /music as aliases to /extern/videos and /extern/music. This works, but /extern still also shows up in the file system with its nested folders (/extern/videos and /extern/music), so that /videos and /music show up twice in the file system.
I tried comment=x-gvfs-hide, and I tried putting both variants in the bind column as well. No success.
Anyone know how I can hide the /extern folder?
Not sure what you are expecting to happen. I have a very similar setup, except my external folders come from a ntfs partition instead of a separate disk. I got the effect which i wanted by adding x-gvfs-hide to the relevant entries in my /etc/fstab file:
UUID=3081902B5B3B414B /media/lukas/data ntfs-3g defaults,auto,user,x-gvfs-hide 0 0
/media/lukas/data/Music /home/lukas/Music none bind,x-gvfs-hide 0 0
/media/lukas/data/Videos /home/lukas/Videos none bind,x-gvfs-hide 0 0
Following this, all three of the annoying side bar entries (similar as seen here) were hidden from my graphical file manager (thunar v4.16.8 in a Xubuntu 21.10). This is what x-gvfs-hide does. However it does NOT magically remove the first mount while still keeping the other two. This means when i type ls /media/lukas/data, the whole partition - with Music/ and Videos/ subdirectories - will still be visible at this point as well, next to being seamlessly accessible as ~/Music and ~/Videos from both command line and thunar.
heslant
  • 181
