I have recently installed Ubuntu 12.04 and would like to make a virtual router for my Android Device which only connects to infrastructure networks and not ad hoc networks.
I would appreciate any tips.
Zanna
  • 72,312
mojo706
  • 601
Run this in a terminal:
sudo apt-get install hostapd
Then, open a text editor program, for example gedit. Copy the following into it.
interface=wlan0
driver=nl80211
ssid=
channel=1
hw_mode=g
auth_algs=1
wpa=3
wpa_passphrase=
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP CCMP
rsn_pairwise=CCMP
Don't forget to fill in the name of your network after ssid= as well as the password after wpa_passphrase=.
After all these, save the file as hostapd.conf in your home folder.
Now, in your terminal:
sudo hostapd hostapd.conf
Turn the Wi-Fi connection on in your devices and enjoy the fast network share!
you might also want to add dhcpd to assign address to your Android device. Alternatively you can configure iptables to use NAT
