I am not able to resize my root. I want to merge the unallocated space to my root partition. My gparted screenshot looks like this
Make sure that you have a good backup of your important Ubuntu files, as this procedure can corrupt or lose data.
Keep these things in mind:
always start the entire procedure with issuing a swapoff on any mounted swap partitions, and end the entire procedure with issuing a swapon on that same swap partition
a move is done by pointing the mouse pointer at the center of a partition and dragging it left/right with the hand cursor
a resize is done by dragging the left/right side of a partition to the left/right with the directional arrow cursor
if any partition can't be moved/resized graphically, you may have to manually enter the specific required numeric data (don't do this unless I instruct you to)
you begin any move/resize by right-clicking on the partition in the lower pane of the main window, and selecting the desired action from the popup menu, then finishing that action in the new move/resize window
Do the following...
Note: if the procedure doesn't work exactly as I outline, STOP immediately and DO NOT continue.
- boot to a Ubuntu Live DVD/USB, in “Try Ubuntu” mode
- start
gparted - move the p4 partition all the way left
- resize the right side of p4 all the way right
- click the Apply icon
- 73,649
I agree with @heynnema. But I being more of a rookie would do it in a simpler way. Download the gparted live disk. Make a bootable USB of it. Boot to it. Open Gparted if it doesn't open automatically.
Right click on the root partition. Choose Resize/Move. Drag the left side to fill the unallocated. Hit Apply. Wait.
Try to reboot. If it fails then you need a bootable USB of Boot repair. Fire that up and let it do its magic.
- 646
