I am trying to:
  1. make some applications transparent using compton on i3wm such that
  2. in tabbed/ stacked mode in i3wm the underlying windows are hidden (or are not drawn).
For example's sake, let us take the application to be zathura.
I tried the following in my compton.conf:
opacity-rule = [
"90:class_g = 'Zathura' && !_NET_WM_STATE@:32a",
"0:_NET_WM_STATE@:32a *= '_NET_WM_STATE_HIDDEN'"
This doesn't make zathura transparent, but zathura is hidden if it is beneath any other transparent window in tabbed/ stacked window.
Next I tried the following in compton.conf:
opacity-rule = [
"90:class_g = 'Zathura'",
This does make zathura transparent, but this draws zathura beneath other windows when in tabbed or stacked mode in i3wm.
I found this and tried the suggested solution. That is, I replaced "0:_NET_WM_STATE@:32a *= '_NET_WM_STATE_HIDDEN'" with
"0:_NET_WM_STATE@[0]:32a = '_NET_WM_STATE_HIDDEN'",
"0:_NET_WM_STATE@[1]:32a = '_NET_WM_STATE_HIDDEN'",
"0:_NET_WM_STATE@[2]:32a = '_NET_WM_STATE_HIDDEN'",
"0:_NET_WM_STATE@[3]:32a = '_NET_WM_STATE_HIDDEN'",
"0:_NET_WM_STATE@[4]:32a = '_NET_WM_STATE_HIDDEN'"
However this made no change. Please help.
My entire compton.conf is as follows:
menu        = { shadow = false; };
dropdown_menu = { shadow = false; };
popup_menu    = { shadow = false; };
utility       = { shadow = false; };
Shadow
shadow = true; no-dnd-shadow = true; no-dock-shadow = true; clear-shadow = true; shadow-radius = 7; shadow-offset-x = -7; shadow-offset-y = -7; shadow-exclude = [ "class_g = 'i3-frame'", "class_g = 'keynav'",
"name = 'Notification'", "class_g ?= 'Notify-osd'", "_GTK_FRAME_EXTENTS@:c" ];
opacity-rule = [
"0:_NET_WM_STATE@[0]:32a = '_NET_WM_STATE_HIDDEN'" ,"0:_NET_WM_STATE@[1]:32a = '_NET_WM_STATE_HIDDEN'" ,"0:_NET_WM_STATE@[2]:32a = '_NET_WM_STATE_HIDDEN'" ,"0:_NET_WM_STATE@[3]:32a = '_NET_WM_STATE_HIDDEN'" ,"0:_NET_WM_STATE@[4]:32a *= '_NET_WM_STATE_HIDDEN'" ];
Fading
fading = true; fade-delta = 5; fade-in-step = 0.03; fade-out-step = 0.03; fade-exclude = [ ];
Other
backend = "xrender"; mark-wmwin-focused = true; mark-ovredir-focused = true; detect-rounded-corners = true; detect-client-opacity = true; refresh-rate = 0; vsync = "none"; dbe = false; focus-exclude = [ "class_g = 'Cairo-clock'" ]; detect-transient = true; detect-client-leader = true; invert-color-include = [ ];
GLX backend
glx-copy-from-front = false; glx-swap-method = "undefined";
Window type settings
wintypes: { tooltip = { fade = true; shadow = true; opacity = 0.75; focus = true; }; };
Inspired_Blue
  • 601
  • 26
