-1
I have bought a new internal HDD hard drive as the previous one is old enough now I use Ubuntu and Kali Linux in dual boot and I have done a lot of customization and don't want to do that again with fresh install how do I clone both Kali Linux and Ubuntu as it is now to the new internal HDD without losing any data?
Copy the entire drive from one to another. The destination drive needs to be bigger or at least the same size as the source:
Boot into an install cd/usb, "try without installing"
Open gnome-disks or gparted or sudo fdisk -l: So you can identify which drive is which.
Open a terminal
sudo dd if=/dev/sdX of=/dev/sdY bs=1M status=progress
substituting X and Y for the device names you found on your system
/dev/sdX - (the old drive) the entire device, not just a partition(ie sdX1,sdX2).
/dev/sdY - (the new drive) again your writing to the entire device.
Should take a while depending on the size.
WU-TANG
  • 3,316
