I've recently installed Ubuntu 20.04.1 LTS in my laptop, every time, when I turn on the laptop, the Wifi option is disabled.
In order to enable it, I've had to run the below command and restart my laptop (everytime).
sudo service network-manager restart
Is there any way, to make Ubuntu automatically detect Wifi, without having to restart the network-manager?
I've disabled Secure boot,
I was unable to connect to Wifi, when I was installing Ubuntu.
I'm dual booting Ubuntu with Windows 10
Please let me know, if you guys know, a permanent fix for this problem,
cat /etc/network/interfaces
output:
cat: /etc/network/interfaces: No such file or directory
cat /etc/netplan/*.yaml
output:
network:
  renderer: NetworkManager
# Let NetworkManager manage all devices on this system
network:
  version: 2
sudo lshw -C network
output:
*-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 15
       serial: b0:6e:bf:ab:d5:4e
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII
       resources: irq:16 ioport:d000(size=256) memory:df304000-df304fff memory:df300000-df303fff
  *-network
       description: Wireless interface
       product: Wireless 8265 / 8275
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: wlp4s0
       version: 78
       serial: 00:e1:8c:42:0f:18
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-42-generic firmware=36.77d01142.0 ip=192.168.1.4 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:132 memory:df100000-df101fff
lshw
output:
  *-network
       physical id: 0
       version: 15
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
  *-network UNCLAIMED
       description: Network controller
       physical id: 0
       version: 78
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: memory:df100000-df101fff
chqdrian
  • 125
Edit your /etc/netplan/*.yaml... keeping the exact same indentation, spacing, and no tabs...
sudo -H gedit /etc/netplan/*.yaml # use the correct .yaml file name
network:
  version: 2
sudo netplan generate
sudo netplan apply
reboot
Then go to the NetworkManager applet at the right side of the top panel and select your wifi network.
Update #1:
  • boot into Windows
  • open the Power control panel
  • choose change what the power buttons do
  • choose change options that are unavailable
  • uncheck fast startup
  • close the Power control panel
  • open an administrative command prompt window
  • type powercfg /h off
  • type chkdsk /f c:
  • approve to run chkdsk at next reboot
  • type chkdsk /f x: (replacing "x" with drive letters of other visible NTFS partitions)
  • reboot into Windows to let chkdsk run on drive C:
heynnema
  • 73,649
