I upgraded to 12.04 (64 bit) today, so far so good, everything worked great, until I tried doing some more advanced stuff.
When I tried adding the toolchain-test ppa, I got a mismatch on distribution. After a try or 4 this changed and linked me to this bug report. So far so good, a weird error but I'm not the only one and it will get fixed right?
But I found it a very weird error, and I also noticed some other (custom) apps behaving weird concerning my distribution version. So I tried to find out what release I'm running, these are the results I got:
>:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu quantal (development branch)
Release:    12.10
Codename:   quantal
>:~$ cat /etc/issue
Ubuntu quantal (development branch) \n \l
Now I'm wondering: did I do something wrong on installation? Did I accidentally download some weird nightly, set up wrong repositories, ...? Or is this simply a bug in some small part of the system that does the reporting wrong and maybe will confuse an app or two?
Now, whatever the reason: is there a simple way I can set this release information to the correct version again?
Jorge Castro
  • 73,717
KillianDS
  • 886
I had the exact same problem. In my case it was due to the fact that I had the ppa:ubuntu-toolchain-r/test enabled and even though only precise was listed as the series, the base-files package in there seems to belong to quantal. To find out from where the misbehaving base-files package is installed, use the following command:
$ apt-cache policy base-files
Find the line where the version matches the installed version and inspect the URL that is reported for that version.
If you want to keep the PPA enabled (e.g. because you want/must use the gcc-4.7 compiler), you can use apt-pinning to force the system into keeping the base-files package while allowing you to install gcc-4.7. Create the file /etc/apt/preferences.d/base-files (make sure not to use any dots in the name) with the following content:
Package: base-files
Pin: release o=Ubuntu
Pin-Priority: 1001
This will force a downgrade of the base-files package to its default version (from the main ubuntu repository) on the next upgrade.
Be extra careful about typographical errors, particularly spaces and capitalization.
Once the file is in place, use apt-cache policy base-files to determine the Candidate version. It should correspond to the version that is listed next to the default Ubuntu archive. Finally, start the downgrade:
$ sudo apt-get upgrade
When asked whether you really want to DOWNGRADE (capitalization not mine...), answer with y+Enter.
Michael Wild
  • 1,739
As far as I know, once a package is upgraded it cannot be downgraded, with the exception being a procedure like REMOVE PACKAGE- > CHANGE REPO- > UPDATE APT -> REINSTALL OLD PACKAGE. Which is a quite odd procedure, as sometimes there are some dependencies and version issues.
Anyway, go to /etc/apt/sources.list and /etc/apt/sources.list.d/*.list and see if there are some rows containing the word "quantal".
If there are, then that's the problem. I would suggest you backup everything and reinstall a clean stable version. The other solution would be to change all the "quantal" words in "precise", re-update repos and hope that all of the quantal packages will be replaced with a more up-to-date precise version. But it's a VERY BAD solution!
belacqua
  • 23,540
