48
I'm running Ubuntu 20.04, and I'm trying to create a hibernate command. I'm following these instructions.
Step 2 says
Then check whether the swap memory you allocated is more than or at least equal to the Physical memory(RAM).
I did that, and my /swapfile is 2 GB. I have 16 GB RAM, so I need to increase the size of that swap file. How do I do that in Ubuntu?
Yehuda
  • 608
In sleep mode, the content of ram is kept as it is, and the computer works on a very low power mode, so as to keep the ram content intact (as ram will lose the data if power supply is cut to it). But in hibernation, the ram content is stored in the swap space, so power can be completely cut off. Hence it is recommended to have swap size as large as the ram size.
  1. First, find the swap file, disable and delete it
     swapon --show
     NAME      TYPE SIZE USED PRIO
     /swapfile file   2G   0B   -2
    sudo swapoff /swapfile
    sudo rm /swapfile
  2. Create new swap space of size 16 GB (16 * 1024 = 16384). bs is the block size. Basically bs * count = bytes to be allocated (in this case 16 GB). Here bs = 1M (M stands for mega, so we are assigning 1MB block size) and we are allocating 16384 * 1MB (=16GB) to swap.
     sudo dd if=/dev/zero of=/swapfile bs=1M count=16384
  3. Give it the read/write permission for root
     sudo chmod 600 /swapfile
  4. Format it to swap
     sudo mkswap /swapfile
  5. Turn on swap again
     sudo swapon /swapfile
  6. Now reboot the PC for the above changes to take place.
TommyPeanuts
  • 1,147
Abhay Patil
  • 2,793
25
Below steps worked for me with fallocate approach
  1. Check for the Swap Information
sudo swapon --show
Output will be something like below,
/swapfile file    2G     0G    -2
  1. Deactivate the swap space
  1. Use fallocate to instantly creates a file with the specified size.
sudo fallocate -l 16G /swapfile
  1. Set the swap space
  1. Activate the swap space
  1. Now check for the Swap Information
sudo swapon --show
Now the output will be something like below,
/swapfile file   16G     0B    -2
Cheers!
Muniraj
  • 889
sudo su -
swapoff /swapfile
rm  /swapfile
\# 32k -> 32GB swap size
dd if=/dev/zero of=/swapfile bs=1M count=32K
mkswap /swapfile
swapon /swapfile
Ctrl+D
