I am trying to install elasticsearch on my remote machine using the following commands ..
wget -qO - https://artifacts.elastic.co/GPG-KEY-elasticsearch | sudo apt-key add -
sudo apt-get install apt-transport-https
echo "deb https://artifacts.elastic.co/packages/7.x/apt stable main" | sudo tee -a /etc/apt/sources.list.d/elastic-7.x.list
sudo apt-get update && sudo apt-get install elasticsearch
While installing, I am getting the following error
The following packages have unmet dependencies: nvidia-cuda-toolkit : Depends: nvidia-cuda-dev (= 9.1.85-3ubuntu1) but it is not going to be installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried with the solutions like
for which i am getting the error
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following package was automatically installed and is no longer required:
  libllvm9
Use 'apt autoremove' to remove it.
The following additional packages will be installed:
  nvidia-cuda-dev
Recommended packages:
  libnvcuvid1
The following NEW packages will be installed:
  nvidia-cuda-dev
0 upgraded, 1 newly installed, 0 to remove and 38 not upgraded.
1 not fully installed or removed.
Need to get 0 B/263 MB of archives.
After this operation, 734 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 175495 files and directories currently installed.)
Preparing to unpack .../nvidia-cuda-dev_9.1.85-3ubuntu1_amd64.deb ...
Unpacking nvidia-cuda-dev (9.1.85-3ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-cuda-dev_9.1.85-3ubuntu1_amd64.deb (--unpack):
 trying to overwrite '/usr/include/cublas.h', which is also in package libcublas-dev 10.2.1.243-1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
**Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)**
I also tried
sudo apt -f install
for which i got the error
  libllvm9
Use 'sudo apt autoremove' to remove it.
  nvidia-cuda-dev
  libnvcuvid1
  nvidia-cuda-dev
Please suggest how to pass this
ubfan1
  • 19,049
args
Try running this command:
sudo apt install cuda-toolkit-9-1
It works for me.
