This seems to be a reoccurring problem. There has been other questions similar to this without a decent answer. Ubuntu 20.04.1 locates the scanner when Document Scanner starts up but when told to scan it fails with "Failed to scan Unable to connect to scanner". The scanner is a HP LaserJet M1522nf network connected which worked without problems under 19.10. The printer portion works just fine. This is a straight upgrade from 19.10 to 20.04.1. Xsane fails with "Failed to open device 'hpaio:/usb/HP_LaserJet_M1522nf_MPF? serial=00CNC986V086':Error during device I/O"
What changed between 19.10 and 20.04 that would affect scanners? Any help would be appreciated.
DanM
  • 61
Install and be happy:
sudo apt install sane-airscan ipp-usb
Why these are not part of the regular installation routine, I have no idea.
When installed, scanning works normally. When not, apparently some scanners still work, but many do not. Perhaps a bug report is in order.
u2n
  • 923
  • 22
