Possible Duplicate:
How burn or mount an ISO file?
i tried burning the ubuntu 12.04 iso image in many cd's and dvd's but the iso file does not get expanded. it shows only the iso file in it and some cd's dont show up anything. i tried burning with infrarecorder and burn windows image option by right clicking. how do i burn the file now?iam using windows 7 32bit and i also have nero (if its of any use). please help me, iam in a big trouble!
Are you sure you are selecting "Burn image to disk" option rather than "burn file to disk"?
Anyways, if you have nero, you can burn an existing image from there. just open nero >> extra >> burn image to disk [this order might change depending upon the nero versio you are using]
After doing that, you should be able to see the contents of the image in the nero window. Just burn the disk and tell me if all goes right.
Cheers
Pawan
  • 225
Expanded? You're saying that you see the ISO file on your burned disc instead of the contents of the ISO file? If that is the case, you used the wrong burn option. Burn the ISO file as an image, do not burn a data CD or DVD containing just the ISO file.
