I have purchased a new desktop and I am trying to run Ubuntu in dual boot with windows 10. I have disabled secure boot and windows fast boot. When I log in to Ubuntu it does not connect to internet via ethernet cable.
sudo lshw -C network Shows realtek driver is unclaimed.
The solution I have searched is to install r8125 driver but I just cannot get the steps accurately. Request to let me know what are the installation steps of installing r8125 driver and run the internet from ethernet cable.
To avoid having to reinstall the driver after every kernel update, create a file called dkms.conf in the NIC's source directory with these lines:
PACKAGE_NAME="r8125"
PACKAGE_VERSION="9.003.05"
BUILT_MODULE_NAME[0]="$PACKAGE_NAME"
DEST_MODULE_LOCATION[0]="/updates/dkms"
AUTOINSTALL="YES"
REMAKE_INITRD="YES"
CLEAN="rm src/@PKGNAME@.ko src/*.o || true"
Modify 9.003.05 to the version number that you have the source code for. To install the driver for the first time:
sudo cp -R /path.to/source/ /usr/src/r8125-9.003.05
sudo dkms add -m r8125 -v 9.003.05
sudo dkms build -m r8125 -v 9.003.05
sudo dkms install -m r8125 -v 9.003.05
To update the version, remove the current one first, remembering to change to the correct version number:
sudo dkms remove r8125/9.002.02 --all
sudo rm -rf /usr/src/r81259.002.02/
sudo dkms status
After the first install, dkms will automatically build and install the driver for you. You will, of course, need dkms installed first.
nospam
  • 422
Somehow stuff breaks if I use the config from @nospam. The following config works for the newest versions, I added the kernelver to the build
$ cat dkms.conf
PACKAGE_NAME="realtek-r8125"
PACKAGE_VERSION="9.005.01"
BUILT_MODULE_NAME[0]="r8125"
DEST_MODULE_LOCATION[0]="/updates"
BUILT_MODULE_LOCATION[0]="src"
MAKE="'make' KVER=${kernelver} BSRC=/lib/modules/${kernelver} all"
AUTOINSTALL="yes"
REMAKE_INITRD="yes"
Or upgrade to the latest version of ubuntu worked for me
Martijn van Wezel
  • 903
  • 13
  • Obtain file from Realtek here (They make it very complicated :-( )
  • Unzip
  • In terminal, change into directory and run sudo ./autorun.sh
Ari Fordsham
  • 143
I found that upgrading to Ubuntu 20.04 is another solution. I have a brand new B550 board and the existing Ubuntu 18.04 installation didn't pick up the 2.5G ethernet, but upgrading to 20.04 solved it for me.
robvdl
  • 83
