I've installed Ubuntu 20.04 on a 2020 HP Omen 15 laptop with AMD CPU and NVidia GPU. Everything works except detecting an external monitor. I have used the "Additional Drivers" software configuration section and unsuccessfully tried all the nvidia drivers listed there (including nvidia-driver-440). The "Displays" setting of the settings app only shows one display, which is titled "Unknown Display". I also noticed that the "Nvidia X Server Settings" App is blank, and also that there is no /etc/X11/xorg.conf file present.
i had the issue with the driver i had installed got corrupted and on installing nvidia-driver-440 and above it started showing dependency error. now the problem i had solved was with complete fresh installation of a Ubuntu 20.04 and installing nvidia-driver-470 this solved for me but you can check
sudo apt-get install nvidia-driver-470
