I used to use the xcalib -i -a command on my old desktop system running 18.04 with an onboard Intel graphics card. This xcalib -i -a command successfully inverted my system colors.
I just got a fancy new 20.04 desktop with a Radeon graphics card and now when I issue the xcalib -i -a command the screen output is just garbled. I can barely make out the terminal and I issue the xcalib -i -a command again to make my screen go "back to normal".
Why doesn't xcalib -i -a work anymore, and is there any other way to quickly invert Ubuntu 20.04 screen colors?
I'm running a default session which I believe is X11 and NOT Wayland. So not sure why I'm having issues. And xrandr --output VGA-0 --brightness -1 does not work, and garbles my screen output the same as described above.
Display name
  • 2,331
The extension "Invert Color" might work for you as a quick-fix if you work in a Gnome environment. See https://github.com/maiself/gnome-shell-extension-invert-color
