I recently installed Ubuntu alongside Windows 10 but am no longer able to access Windows when rebooting. On start up my computer, which is booting through UEFI, goes straight to GRUB but there is no option to select the Windows OS. There also does not seem to be an option for Windows when selecting from the boot menu. The Windows files are still viewable in the partition I created before installing Ubuntu and Boot-Repair did not fix the problem.https://paste.ubuntu.com/p/9TFcF7SKZK/ is the paste that boot repair provided me please help me i'm in trouble without windows.
These are sudo fdisk -l results
root@karl:~# sudo fdisk -l
Disk /dev/loop0: 54.97 MiB, 57614336 bytes, 112528 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 54.98 MiB, 57626624 bytes, 112552 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop2: 240.82 MiB, 252493824 bytes, 493152 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop3: 255.58 MiB, 267980800 bytes, 523400 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop4: 62.9 MiB, 65105920 bytes, 127160 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop5: 49.8 MiB, 52203520 bytes, 101960 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop6: 49.8 MiB, 52203520 bytes, 101960 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop7: 27.9 MiB, 28405760 bytes, 55480 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sdb: 465.78 GiB, 500107862016 bytes, 976773168 sectors Disk model: WDC WD5000AAKX-6 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: FB3C3F69-0430-4285-8FE3-364A118CD32E
Device Start End Sectors Size Type /dev/sdb1 2048 1050623 1048576 512M BIOS boot /dev/sdb2 1050624 976771071 975720448 465.3G Linux filesystem
Disk /dev/sda: 465.78 GiB, 500107862016 bytes, 976773168 sectors Disk model: CT3500SC
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x612b88ea
Device Boot Start End Sectors Size Id Type /dev/sda1 206848 204799999 204593152 97.6G 7 HPFS/NTFS/exFAT
Disk /dev/loop8: 29.9 MiB, 31334400 bytes, 61200 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop9: 290.45 MiB, 304545792 bytes, 594816 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop10: 4.93 GiB, 5268953088 bytes, 10290924 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sdc: 14.47 GiB, 15525216256 bytes, 30322688 sectors Disk model: v236w
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x229ce8de
Device Boot Start End Sectors Size Id Type /dev/sdc1 2048 30322687 30320640 14.5G 7 HPFS/NTFS/exFAT
Kulfy
  • 18,154
You need to edit your grub.conf your not in trouble trust me, save and
sudo update grub
