This seems a very simple problem but it's driving me nuts. I'm trying to mount two ext4 partitions at boot time with /etc/fstab.(They are written differently because I read in a forum that there were some problems mounting by uuid)
Here are the two lines:
UUID=c7fa17c3-e1e0-489e-93ec-341928069664 /home/alice/VirtualGarden ext4 rw,suid,dev,exec,auto,user,async 0 2
/dev/sda8 /home/alice/Saco  ext4 rw,suid,dev,exec,auto,user,async 0 3
The main problem is that after boot I won't have access to either partition. They appear in my desktop, but when I try to list their content they are empty. Everything works if I mount them as a normal user after boot. For example:
mount /home/alice/Saco
I don't know if this makes a difference, but the mount point (/home/alice/) is an encrypted partition. I tried to move the mount point to /Saco and it mounted perfectly after reboot.
Another thing is that if I use the UUID in fstab Nautilus creates two links for the same partition. I did some research and I have solved this by using /dev/disk/by-uuid/.
Any tips or advise are welcome.
Jorge Castro
  • 73,717
alxlenc
  • 1,067
Your encrypted partition doesn't get mounted unless you provide the password, while the system tries to mount the other partitions before that happens.
The obvious advise: mount your partitions somewhere else (eg., /media/alice/... or /mnt/alice/...). You can place a symlink to those mount points, if you absolutely want them to be accessible from /home/alice/...:
ln -s /media/alice/VirtualGarden /home/alice/VirtualGarden
ln -s /media/alice/Saco /home/alice/Saco
htorque
  • 66,086
Why do you use the manual way if you are unclear,install ntfs-config to automount partitions.I have been using this in 10.04 for few months.It is good,just try it.
Installation:
sudo apt-get install ntfs-config
Also see this post
karthick87
  • 84,513
It seems that your encrypted partition is mounted after the system has tried to mount /home/alice/Saco. As there is no /home/alice at the time system try to mount /home/alice/Saco, then this partition is not mounted but is available to be mounted manually after the system has been booted up. Would you provide information about when you mount your /home/alice encrypted.
