I want to install Ceph on my laptop for some dev stuff but the problem is Ceph requires a raw disk or partition.
How I can create a new raw partition from my free space?
At the moment my disk is as below:
$sudo fdisk -l
Disk /dev/nvme0n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 0722C9AB-A32C-4447-8607-F646E10E1CFF
Device Start End Sectors Size Type /dev/nvme0n1p1 2048 1050623 1048576 512M EFI System /dev/nvme0n1p2 1050624 1312767 262144 128M Microsoft reserved /dev/nvme0n1p3 1312768 394058702 392745935 187,3G Microsoft basic data /dev/nvme0n1p4 394059776 1000214527 606154752 289G Linux filesystem
$sudo df -h -T Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 7,8G 0 7,8G 0% /dev tmpfs tmpfs 1,6G 3,9M 1,6G 1% /run /dev/nvme0n1p4 ext4 284G 130G 140G 49% / tmpfs tmpfs 7,8G 539M 7,3G 7% /dev/shm tmpfs tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs tmpfs 7,8G 0 7,8G 0% /sys/fs/cgroup /dev/nvme0n1p1 vfat 508M 31M 478M 6% /boot/efi tmpfs tmpfs 1,6G 56K 1,6G 1% /run/user/1000
AVarf
  • 123
If you want you can use gnome-disks utility as graphical solution resize your current partition and clear the partition removed. But sometimes resizing the partition can cause some issues so be careful when resizing, make sure to do a disk fragmentation before you resize it. Usually the minimal size you needed for an installtion is 20GB try to give that partition no less than that.
Ahmad Eid
