The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please reinstall virtualbox-dkms package and load the kernel module by executing'modprobe vboxdrv' as root.If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
I tried certain commands like
sudo modprobe vboxdrv
showing this error
Could not insert 'vboxdrv': Operation not permitted
How can I solve this?
Zanna
  • 72,312
Boomer
  • 19
Am having the same issue over here, upgraded from 18.04 to 20.04 and am having trouble with virtual box, it says the same thing as the original post says
