I experience this too, with fresh Ubuntu 20.04 installation. I see the root cause of this was found ( https://bugs.launchpad.net/ubuntu/+source/mutter/+bug/1892440 ).
I can offer my workaround: add to autostart a trivial command that explicitly sets the "text scaling factor" after login. This change will be correctly noticed by the GNOME shell, making the GNOME shell text correctly scaled.
To do this, create a file $HOME/.config/autostart/fix-font-scaling.desktop with this content:
[Desktop Entry]
Name=Fix Font Scaling
GenericName=Fix Font Scaling
Exec=/home/michalis/bin/fix-font-scaling.sh
Terminal=false
Type=Application
StartupNotify=false
X-GNOME-Autostart-enabled=true
Where /home/michalis/bin/ is just an example, it's where I keep the script.
Then make a script /home/michalis/bin/fix-font-scaling.sh with contents like this:
#!/bin/bash
set -eu
wait a bit, otherwise the change seems to not be noticed properly
sleep 1s
change to 1.5 then to 1.25, it seems necessary for GNOME shell to register this "change"
gsettings set org.gnome.desktop.interface text-scaling-factor 1.5
gsettings set org.gnome.desktop.interface text-scaling-factor 1.25
Make it executable (chmod +x /home/michalis/bin/fix-font-scaling.sh).
And adjust the 1.25 above as needed.
Note that this overrides the text scaling you have set by settings ("Accessibility -> Large Text", or GNOME tweak tool "text scaling").
Note: what does set -eu do?
It makes writing bash scripts safer, so I learned to use this automatically in all my bash scripts :)
It's a shortcut for set -e and set -u.
The set -e means that a bash script will exit with non-zero status as soon as some command exits with non-zero status. E.g. if sleep command fails for any weird reason, then following gsettings calls will not be done. Without set -e, bash scripts happily continue their execution, even when something along the way reported failure.
The set -u means that the script fails when you try to use an undefined variable, like echo ${SOMETHING_UNDEFINED}. So set -u allows to catch errors in the script easier. It has no effect in this particular script that uses no variables :) It's was just my force of habit to use it.
There's a great article discussing this (and some related) bash constructs, to make bash scripts easier to write/debug, on http://redsymbol.net/articles/unofficial-bash-strict-mode/ .
