Attempting to upgrade from 18.04 to 20.04 using:
sudo do-release-upgrade -d -f DistUpgradeViewGtk3
This fails with the message:
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by: * Unofficial software packages not provided by Ubuntu Please use the tool 'ppa-purge' from the ppa-purge package to remove software from a Launchpad PPA and try the upgrade again.
Prior to this I get a notice that third-party sources are being disabled for the upgrade.
The contents of main.log is Here
It says at the end:
2020-07-26 08:53:18,226 WARNING Can't mark 'ubuntu-desktop' for upgrade (E:Unable to correct problems, you have held broken packages.) 2020-07-26 08:53:28,026 ERROR Dist-upgrade failed: 'Broken packages after upgrade: ubuntu-desktop'
As a result, I have tried all of the broken packages solutions I could find, none of which have worked. Running synaptic package manager and filtering by broken finds no packages.
I have installed ppa-purge but without an idea of which packages to remove with it, I haven't actually used it.
I had this same problem and was able to resolve it using this answer https://askubuntu.com/a/646918/309267
Update: The above answer didn't help on my second computer but this one works great https://askubuntu.com/a/1242078
