my question similar to: How to write an init script that will execute an existing start script?
However, that question is outdated and I like to know how I can do that in Ubuntu 20.04
This my try in init.d directory:
#! /bin/sh
### BEGIN INIT INFO
# Provides:          myrec
# Required-Start:    $all
# Required-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:
# Short-Description: your description here
### END INIT INFO
PATH=/home/ahmad/recordings DESC="Recording audio output" NAME=myrec DAEMON=/home/ahmad/recordings/myrec.sh PIDFILE=/var/run/$NAME.pid SCRIPTNAME=/etc/init.d/$NAME
  • I would like to run it after all processes executed, so should I use a systemd service or the above is okay?
  • Should I add other code to above or it runs my sh (myrec.sh) file?
In general What is a hello world for executing a simple bash (so that I can see the result) for ubuntu 20.04? Every thing I found in the web is outdated
Ahmad
  • 652
There are two common ways to start a service on Ubuntu:
  1. Making a service file in /etc/init.d directory.
You can check the existing ones as examples. There used to be a template file named skeleton which is no more exists. However you can find a basic example and more help by running man init-d-script.
After creating the file run sudo update-rc.d myservice defaults to install your service (here referred as myservice). refer to update-rec.d, Then you can start and stop your service using sudo service myservice start
  1. The second and recommended or new one is creating a SystemD service.
To know the difference with the above check: Difference between systemctl init.d and service
Here is a simple example of how to create and run your service:
https://www.linode.com/docs/quick-answers/linux/start-service-at-boot/
You can also refer to his manual page for detailed descriptions of these two styles:
http://0pointer.de/public/systemd-man/daemon.html
Ahmad
  • 652
