I run the following command to capture the output of audio into a file:
$ sox -t pulseaudio alsa_output.pci-0000_00_1b.0.analog-stereo.monitor -t mp3 test.mp3 silence 1 0.1 3% 1 3.0 3% > /dev/null
Input File : 'alsa_output.pci-0000_00_1b.0.analog-stereo.monitor' (pulseaudio) Channels : 2 Sample Rate : 48000 Precision : 16-bit Sample Encoding: 16-bit Signed Integer PCM
In:0.00% 00:00:18.09 [00:00:00.00] Out:0 [ | ] Clip:0 ^C[C
As you see, while I tried to send the output to null, it stills show messages about the progress and status of recording!
I want it to record in background without showing these messages so that I can have the terminal prompts....
I checked sox for a log file but didn't find
Ahmad
  • 652
sox has -q option if you don't want to see the messages.
You also forgot to specify what you want to send to /dev/null. It must be 1 (STDOUT), 2 (STDError) or & or 1&2 meaning both. check What does 2>/dev/null mean?
If you want to run the command in background add & at the end of command.
So it must be one of the followings:
sox -q -t pulseaudio alsa_output.pci-0000_00_1b.0.analog-stereo.monitor -t mp3 test.mp3 silence 1 0.1 3% 1 3.0 3%  &
OR:
sox -t pulseaudio alsa_output.pci-0000_00_1b.0.analog-stereo.monitor -t mp3 test.mp3 silence 1 0.1 3% 1 3.0 3% &>/dev/null &
Ahmad
  • 652
