My problem is similar if not identical to Ubuntu 20.04, every boot makes a very long filesystem check having insufficient reputation to comment for joining the club.
Dual boot Linux/Windows system on an HP SSD equipped notebook using grub boot loader. Worked perfectly with 19.04. Did an upgrade to 20.04 shortly after release. On second (??) reboot after the grub screen a file system check message containing a spinner showed up endlessly. Moreover the promised »Ctrl-C« to interrupt did not work at all.
I then re-installed 19.04 working perfectly again. Today reaching 19.04 end of support I thought 20.04 might have improved but to no avail! The spinner turned endlessly again »Ctrl-C« not helping an inch.
Strangely the very first reboot after upgrading to 20.04 succeeded: I saw the file system check message disappearing after five seconds as expected before successfully continuing the reboot process. But on second reboot I got stuck again.
I employed the GRUB_CMDLINE_LINUX_DEFAULT="fsck.mode=skip ..." workaround but obviously a file system check at boot time is advised.
My /etc/fstab contains four entries corresponding to /, /boot/efi, /home and swap:
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/nvme0n1p6 during installation
UUID=ca0eb0c0-9606-41e4-873f-de0e3ba10266 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/nvme0n1p2 during installation
UUID=288C-F264 /boot/efi vfat umask=0077 0 1
# /home was on /dev/nvme0n1p7 during installation
UUID=743bb313-9845-4aed-a1ad-6b97ed4fac01 /home ext4 defaults 0 2
# swap was on /dev/nvme0n1p5 during installation
UUID=f0f43222-3cdb-4059-acfc-af13b09190d9 none swap sw 0 0
fdisk -l relevant portion:
Disk /dev/nvme0n1: 953,89 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: KXG50ZNV1T02 TOSHIBA
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 12EEC9A1-6277-423E-B253-0B603CF869C7
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1023999 1021952 499M Windows recovery environment
/dev/nvme0n1p2 1024000 1228799 204800 100M EFI System
/dev/nvme0n1p3 1228800 1261567 showing 32768 16M Microsoft reserved
/dev/nvme0n1p4 1261568 204802047 203540480 97,1G Microsoft basic data
/dev/nvme0n1p5 204802048 206755839 1953792 954M Linux swap
/dev/nvme0n1p6 206755840 437909503 231153664 110,2G Linux filesystem
/dev/nvme0n1p7 437909504 2000408575 1562499072 745,1G Linux filesystem
Using a live boot system both fsck /dev/nvme0n1p6 and fsck /dev/nvme0n1p7 execute flawlessly almost immediately reporting two »clean« file systems. Forcing a file system check yields a correctable warning for the /home partition:
root@ubuntu:~# e2fsck -f /dev/nvme0n1p7
e2fsck 1.45.3 (14-Jul-2019)
Pass 1: Checking inodes, blocks, and sizes
Inode 43787646 extent tree (at level 1) could be shorter. Optimize<y>? yes
Pass 1E: Optimizing extent trees
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/nvme0n1p7: ***** FILE SYSTEM WAS MODIFIED *****
/dev/nvme0n1p7: 240030/48832512 files (1.9% non-contiguous), 54063796/195312384 blocks
Subsequent e2fsck -f /dev/nvme0n1p7 report no warnings.
tune2fs -l /dev/nvme0n1p6
tune2fs 1.45.3 (14-Jul-2019)
Filesystem volume name: <none>
Last mounted on: /
Filesystem UUID: ca0eb0c0-9606-41e4-873f-de0e3ba10266
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: has_journal ext_attr resize_inode dir_index filetype extent 64bit flex_bg sparse_super large_file huge_file dir_nlink extra_isize metadata_csum
Filesystem flags: signed_directory_hash
Default mount options: user_xattr acl
Filesystem state: clean
Errors behavior: Continue
Filesystem OS type: Linux
Inode count: 7225344
Block count: 28894208
Reserved block count: 1444710
Free blocks: 23465464
Free inodes: 6742890
First block: 0
Block size: 4096
Fragment size: 4096
Group descriptor size: 64
Reserved GDT blocks: 1024
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8192
Inode blocks per group: 512
Flex block group size: 16
Filesystem created: Fri Apr 24 05:43:28 2020
Last mount time: Tue Jul 21 08:18:20 2020
Last write time: Tue Jul 21 08:18:19 2020
Mount count: 5
Maximum mount count: -1
Last checked: Tue Jul 21 07:30:25 2020
Check interval: 0 (<none>)
Lifetime writes: 64 GB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 32
Desired extra isize: 32
Journal inode: 8
Default directory hash: half_md4
Directory Hash Seed: 23aac590-850f-4f42-9368-55601ba5eec0
Journal backup: inode blocks
Checksum type: crc32c
Checksum: 0xbfd90acb
tune2fs -l /dev/nvme0n1p7
Last mounted on: /home
Filesystem UUID: 743bb313-9845-4aed-a1ad-6b97ed4fac01
Inode count: 48832512
Block count: 195312384
Reserved block count: 9765619
Free blocks: 141232260
Free inodes: 48592695
First block: 0
Block size: 4096
Fragment size: 4096
Filesystem created: Mon Dec 30 14:12:27 2019
Last mount time: Tue Jul 21 08:18:21 2020
Last write time: Tue Jul 21 08:18:21 2020
Mount count: 5
Last checked: Tue Jul 21 07:30:33 2020
Lifetime writes: 359 GB
First inode: 11
Inode size: 256
Journal inode: 8
Directory Hash Seed: c6477151-86b4-4275-b627-ce2568be458f
Checksum: 0xa5c6ce45
SMART check:
nvme smart-log /dev/nvme0
Smart Log for NVME device:nvme0 namespace-id:ffffffff
critical_warning : 0
temperature : 31 C
available_spare : 100%
available_spare_threshold : 5%
percentage_used : 1%
data_units_read : 3.459.789
data_units_written : 3.987.840
host_read_commands : 59.275.018
host_write_commands : 52.110.771
controller_busy_time : 191
power_cycles : 863
power_on_hours : 1.091
unsafe_shutdowns : 147
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 31 C
Thermal Management T1 Trans Count : 0
Thermal Management T2 Trans Count : 0
Thermal Management T1 Total Time : 0
Thermal Management T2 Total Time : 0
