I recently installed Ubuntu 18.04 on my Asus Vivo laptop alongside Windows 10. That loaded correctly. Yesterday I installed Ubuntu 20.04 by manually creating partitions. The installation went smoothly, however on restart, grub doesn't load Ubuntu 20.04 but shows a terminal instead. I tried Boot-Repair via a live USB, but it didn't work.
Here a link to Boot-Repair report.
============================== Boot Info Summary ===============================
=> No boot loader is installed in the MBR of /dev/sda. => Syslinux MBR (3.61-4.03) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system:       vfat
Boot sector type:  Windows 8/2012: FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:
sda2: __________________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
sda3: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Windows 8/2012: NTFS
Operating System:  Windows 10
Boot files:
sda4: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sda5: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sda6: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sda7: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sda8: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 20.04 LTS
Boot files:        /etc/fstab /etc/default/grub
sda9: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  SYSLINUX 4.03 2010-10-22 ........>..sr>........p.8...0...~.....~...f...M.f.f....f..0~....>E}.u......
Boot sector info:  Syslinux looks at sector 7856530 of /dev/sdb1 for its
                   second stage. SYSLINUX is installed in the  directory.
                   The integrity check of the ADV area failed. No errors
Operating System:
Boot files:        /boot/grub/grub.cfg /syslinux.cfg
                   /efi/BOOT/grubx64.efi /efi/BOOT/mmx64.efi /ldlinux.sys
================================ 1 OS detected =================================
OS#1: Windows 10 on sda3
============================ Architecture/Host Info ============================
CPU architecture: 64-bit Live-session OS is Ubuntu 64-bit (Ubuntu 20.04 LTS, focal, x86_64)
===================================== UEFI =====================================
BIOS is EFI-compatible, and is setup in EFI-mode for this live-session. SecureBoot disabled.
efibootmgr -v BootCurrent: 0003 Timeout: 1 seconds BootOrder: 0002,0000,0003 Boot0000* Windows Boot Manager HD(1,GPT,a79d2df9-4212-47e0-b432-fbbf1fafc664,0x800,0x82000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...})............... Boot0002* ubuntu HD(1,GPT,a79d2df9-4212-47e0-b432-fbbf1fafc664,0x800,0x82000)/File(\EFI\UBUNTU\SHIMX64.EFI) Boot0003* UEFI: hp v236w 0009, Partition 1 PciRoot(0x0)/Pci(0x15,0x0)/USB(2,0)/HD(1,MBR,0xfc5c173b,0x800,0x1ce7800)..BO
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sda1 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda3 : is-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda4 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda5 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda6 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda8 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios sda9 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
Partitions info (2/3): _________________________________________________________
sda1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot sda4 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda5 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda6 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot sda8 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda9 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
sda1 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda3 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda4 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda5 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda6 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda8 : maybesepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda sda9 : maybesepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors Disk identifier: E28396D1-E1AC-4593-89BB-922C4A46F666 Start End Sectors Size Type sda1 2048 534527 532480 260M EFI System sda2 534528 567295 32768 16M Microsoft reserved sda3 567296 297527295 296960000 141.6G Microsoft basic data sda4 848977920 1400428543 551450624 263G Microsoft basic data sda5 1400428544 1951883263 551454720 263G Microsoft basic data sda6 1951885312 1953523711 1638400 800M Windows recovery environment sda7 832976896 848977919 16001024 7.6G Linux swap sda8 297527296 337526783 39999488 19.1G Linux filesystem sda9 337526784 477526015 139999232 66.8G Linux filesystem Partition table entries are not in disk order. Disk sdb: 14.46 GiB, 15518924800 bytes, 30310400 sectors Disk identifier: 0xfc5c173b Boot Start End Sectors Size Id Type sdb1 * 2048 30310399 30308352 14.5G b W95 FAT32
parted -lm (filtered): _________________________________________________________
sda:1000GB:scsi:512:4096:gpt:ATA TOSHIBA MQ04ABF1:; 1:1049kB:274MB:273MB:fat32:EFI system partition:boot, esp; 2:274MB:290MB:16.8MB::Microsoft reserved partition:msftres; 3:290MB:152GB:152GB:ntfs:Basic data partition:msftdata; 8:152GB:173GB:20.5GB:ext4::; 9:173GB:244GB:71.7GB:ext4::; 7:426GB:435GB:8193MB:linux-swap(v1)::swap; 4:435GB:717GB:282GB:ntfs:Basic data partition:msftdata; 5:717GB:999GB:282GB:ntfs:Basic data partition:msftdata; 6:999GB:1000GB:839MB:ntfs:Basic data partition:hidden, diag; sdb:15.5GB:scsi:512:512:msdos:hp v236w:; 1:1049kB:15.5GB:15.5GB:fat32::boot;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 vfat 9683-38A0 a79d2df9-4212-47e0-b432-fbbf1fafc664 SYSTEM EFI system partition ├─sda2 b09a32e4-70bc-479b-b134-b0645eeca389 Microsoft reserved partition ├─sda3 ntfs DEA0857AA0855A43 f3bd20b9-ff5b-4698-85bb-700a06cee016 OS Basic data partition ├─sda4 ntfs C854CA8154CA71AC 7d899b33-1d27-41f0-b6ee-e696916a0ca0 Basic data partition ├─sda5 ntfs FE1AD14B1AD10217 74b3171d-e99f-469f-af9a-e9a8f8ec8fda Basic data partition ├─sda6 ntfs EEA08356A0832465 dc37e61c-33cb-459e-ad5a-8617fa3df6f8 RECOVERY Basic data partition ├─sda7 swap 455b66d3-da04-437d-9f42-b599b2a26cba d765f7e4-7d19-4238-8668-9c550fab6f02
├─sda8 ext4 5323d7bc-4339-4c44-86bf-8ff4d879e0f6 e7909a77-09ea-4628-8a33-c728d3142fe0
└─sda9 ext4 48ec757e-c739-4b5d-813f-0fe5642a4833 a8864d61-190f-4dd5-aa65-0e7ff597f47d
sdb
└─sdb1 vfat 7DBB-1403 fc5c173b-01 TWINCY
df (filtered): _________________________________________________________________
               Avail Use% Mounted on
sda1 /mnt/boot-sav/sda8/boot/efi sda3 51.4G 64% /mnt/boot-sav/sda3 sda4 /mnt/boot-sav/sda4 sda5 /mnt/boot-sav/sda5 sda6 /mnt/boot-sav/sda6 sda8 13.1G 25% /mnt sda8 /mnt/boot-sav/sda8 sda9 /mnt/boot-sav/sda8/boot sdb1 10.7G 26% /cdrom
Mount options: __________________________________________________________________
sda1 rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro sda3 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 sda4 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 sda5 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 sda6 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 sda8 rw,relatime sda8 rw,relatime sda9 rw,relatime sdb1 ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
========================== sda8/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda8 during installation
UUID=5323d7bc-4339-4c44-86bf-8ff4d879e0f6 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
/home was on /dev/sda9 during installation
UUID=48ec757e-c739-4b5d-813f-0fe5642a4833 /home ext4 defaults 0 2
swap was on /dev/sda7 during installation
UUID=455b66d3-da04-437d-9f42-b599b2a26cba none swap sw 0 0 UUID=48ec757e-c739-4b5d-813f-0fe5642a4833 /boot ext4 defaults 0 2 UUID=9683-38A0 /boot/efi vfat defaults 0 1
======================= sda8/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=hidden GRUB_TIMEOUT=0 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX=""
==================== sda8: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
143.606441498 = 154.196242432 boot/vmlinuz 2 143.606441498 = 154.196242432 boot/vmlinuz-5.4.0-26-generic 2 158.175811768 = 169.839984640 boot/vmlinuz-5.4.0-26-generic.efi.signed 1 143.606441498 = 154.196242432 boot/vmlinuz.old 2
===================== sda8: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 17123 Apr 15 11:31 10_linux -rwxr-xr-x 1 root root 42128 Apr 15 11:31 10_linux_zfs -rwxr-xr-x 1 root root 12894 Apr 15 11:31 20_linux_xen -rwxr-xr-x 1 root root 12059 Apr 15 11:31 30_os-prober -rwxr-xr-x 1 root root 1424 Apr 15 11:31 30_uefi-firmware -rwxr-xr-x 1 root root 214 Apr 15 11:31 40_custom -rwxr-xr-x 1 root root 216 Apr 15 11:31 41_custom
====================== sdb1/boot/grub/grub.cfg (filtered) ======================
Ubuntu Ubuntu (safe graphics) OEM install (for manufacturers) Boot from next volume UEFI Firmware Settings
========================= sdb1/syslinux.cfg (filtered) =========================
default menu.c32 prompt 0 menu title UNetbootin timeout 100
label unetbootindefault menu label Default kernel /ubnkern append initrd=/ubninit file=/cdrom/preseed/ubuntu.seed quiet splash ---
label ubnentry0 menu label ^Help kernel /ubnkern append initrd=/ubninit
label ubnentry1 menu label ^Try Ubuntu without installing kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed quiet splash ---
label ubnentry2 menu label ^Try Ubuntu without installing (safe graphics) kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed quiet splash nomodeset ---
label ubnentry3 menu label ^Install Ubuntu kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed only-ubiquity quiet splash ---
label ubnentry4 menu label ^Install Ubuntu (safe graphics) kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed only-ubiquity quiet splash nomodeset ---
label ubnentry5 menu label Test ^memory kernel /install/mt86plus append initrd=/ubninit
label ubnentry6 menu label ^Boot from first hard disk kernel /ubnkern append initrd=/ubninit
label ubnentry7 menu label Ubuntu kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed maybe-ubiquity quiet splash ---
label ubnentry8 menu label Ubuntu (safe graphics) kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed maybe-ubiquity quiet splash nomodeset ---
label ubnentry9 menu label OEM install (for manufacturers) kernel /casper/vmlinuz append initrd=/casper/initrd file=/cdrom/preseed/ubuntu.seed only-ubiquity quiet splash oem-config/enable=true ---
==================== sdb1: Location of files loaded by Grub ====================
        ?? = ??             boot/grub/grub.cfg                             1
================== sdb1: Location of files loaded by Syslinux ==================
        ?? = ??             syslinux.cfg                                   1
        ?? = ??             ldlinux.sys                                    1
        ?? = ??             menu.c32                                       1
=============== sdb1: Version of COM32(R) files used by Syslinux ===============
menu.c32 : COM32R module (v4.xx)
=============================== StdErr Messages ================================
/usr/share/boot-sav/b-i-s-functions.sh: line 2168: cd: /mnt/boot-sav/sda8/boot/efi/: No such file or directory /usr/share/boot-sav/b-i-s-functions.sh: line 2168: cd: /mnt/boot-sav/sda4/: No such file or directory /usr/share/boot-sav/b-i-s-functions.sh: line 2168: cd: /mnt/boot-sav/sda5/: No such file or directory /usr/share/boot-sav/b-i-s-functions.sh: line 2168: cd: /mnt/boot-sav/sda6/: No such file or directory /usr/share/boot-sav/b-i-s-functions.sh: line 2168: cd: /mnt/boot-sav/sda8/boot/: No such file or directory /usr/share/boot-sav/b-i-s-functions.sh: line 884: [: 2.73495e+09: integer expression expected
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would not act on the MBR. Additional repair would be performed: win-legacy-basic-fix
karel
  • 122,292
  • 133
  • 301
  • 332
