For background, yesterday I tried to upgrade from 18.04 to 20.04 using the itsfoss guide and immediately ran into trouble. My cpu exceeds system requirements, however, it came with Win 10 and I dual-booted Ubuntu shortly after purchase 2 yrs ago. I've used Ubuntu as an OS for over 8 years, but I am a Linux novice who is mostly limited to copying and pasting instructions into the terminal window. It's likely the problem is me due to poor understanding of system architecture/disk partitioning and/or lack of regular maintenance after version upgrades.
When I first ran sudo apt update && sudo apt dist-upgrade I immediately had error messages about lacking appropriate signatures and spent hours yesterday searching for and attempting troubleshooting, but didn't get anywhere except different error messages. I saved my files prior to starting and I probably would consider wiping the cpu and starting over were it not for the fact that I am dual-booted with windows and fear that would be a bigger challenge for me. So, as you read my current error msg below, let me know if you think erasing everything and installing 20.04 from scratch is the better option (and if there are any warnings I'd need to know). Orr, is there a way to get this to work?
Currently, my Software Updater says "Not all updates can be installed" and says that I can continue with a partial upgrade. After researching partial upgrades, it looks like that is a bad idea that doesn't work out well for amateurs like me, so I have not tried that yet.
Thank you for looking this over! Here are the last 4 error messages in my terminal, (most recent first):
sj@sj-lenovo-yoga-920:~$ sudo update-manager
[sudo] password for sj:
WARNING:root:Error loading .desktop file /usr/share/applications/vim.desktop: constructor returned NULL
(software-properties-gtk:10419): IBUS-WARNING **: 00:15:14.586: The owner of /home/sj/.config/ibus/bus is not root!
(software-properties-gtk:10419): IBUS-WARNING **: 00:15:14.848: Unable to connect to ibus: Unexpected lack of content trying to read a line
Checking for a new Ubuntu release
/usr/lib/python3/dist-packages/DistUpgrade/DistUpgradeFetcher.py:23: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
from gi.repository import Gtk, Gdk
/usr/lib/python3/dist-packages/DistUpgrade/ReleaseNotesViewerWebkit.py:33: PyGIWarning: WebKit2 was imported without specifying a version first. Use gi.rerequire_versionquire_version('WebKit2', '4.0') before import to ensure that the right version gets loaded.
from gi.repository import WebKit2 as WebKit
(do-release-upgrade:4796): IBUS-WARNING **: 23:31:37.339: The owner of /home/sj/.config/ibus/bus is not root!
Gtk-Message: 23:31:37.348: GtkDialog mapped without a transient parent. This is discouraged.
(do-release-upgrade:4796): IBUS-WARNING **: 23:31:37.349: Unable to connect to ibus: Unexpected lack of content trying to read a line
authenticate 'focal.tar.gz' against 'focal.tar.gz.gpg'
Gtk-Message: 23:31:50.285: GtkDialog mapped without a transient parent. This is discouraged.
/usr/lib/python3/dist-packages/DistUpgrade/ReleaseNotesViewerWebkit.py:33: PyGIWarning: WebKit2 was imported without specifying a version first. Use gi.require_version('WebKit2', '4.0') before import to ensure that the right version gets loaded.
(do-release-upgrade:5692): IBUS-WARNING **: 23:36:09.636: The owner of /home/sj/.config/ibus/bus is not root!
Gtk-Message: 23:36:09.646: GtkDialog mapped without a transient parent. This is discouraged.
(do-release-upgrade:5692): IBUS-WARNING **: 23:36:09.646: Unable to connect to ibus: Unexpected lack of content trying to read a line
Gtk-Message: 23:36:21.886: GtkDialog mapped without a transient parent. This is discouraged.
(software-properties-gtk:2963): IBUS-WARNING **: 23:26:10.206: The owner of /home/sj/.config/ibus/bus is not root!
NOTE: Deleted 2 Warning entries because filter said they look like spam
(software-properties-gtk:2963): Gtk-CRITICAL **: 23:26:35.954: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkNotebook
NOTE: Deleted 2 additional IBUS warnings because filter thought it was spam
Gtk-Message: 23:28:00.767: GtkDialog mapped without a transient parent. This is discouraged.
sj@sj-lenovo-yoga-920:~$ sudo apt update && sudo apt dist-upgrade
NOTE: This msg is full of links to ubuntu releases. Because I am a new member, I am limited to 8 links per post. Therefore I deleted the first 7 that were ok and I've removed "http:" from the beginning of the rest in hope it passes the filter
Get:8 http://us.old-releases.ubuntu.com/ubuntu bionic InRelease
Err:8 http://us.old-releases.ubuntu.com/ubuntu bionic InRelease
Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Hit:9 //archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign:10 //old-releases.ubuntu.com/ubuntu bionic-security InRelease -
Get:11 //us.old-releases.ubuntu.com/ubuntu artful InRelease
Err:11 //us.strong textold-releases.ubuntu.com/ubuntu artful InRelease
Err:12 http://old-releases.ubuntu.com/ubuntu bionic-security Release
404 Not Found [IP: 2001:67c:1360:8001::25 80]
Get:13 //us.o
NOTE: deleted about 100 similar lines b/c filter thought was spam
Apologies to all for the messy question - I can usually work things out, but this one has been tough. Please let me know if you need additional info or more copypasta from my terminal.
