I try to apt-get upgrade, but there is an error:
update-initramfs: Generating /boot/initrd.img-4.4.0-179-generic
gzip: stdout: No space left on device E: mkinitramfs failure cpio 141 gzip 1 update-initramfs: failed for /boot/initrd.img-4.4.0-179-generic with 1. dpkg: error processing package initramfs-tools (--configure): subprocess installed post-installation script returned error exit status 1 Processing triggers for libc-bin (2.23-0ubuntu11.2) ... Errors were encountered while processing: linux-firmware initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1)
I tried autoremove:
$ sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up initramfs-tools (0.122ubuntu8.16) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-firmware (1.157.23) ...
gzip: stdout: No space left on device E: mkinitramfs failure cpio 141 gzip 1 update-initramfs: failed for /boot/initrd.img-4.4.0-179-generic with 1. dpkg: error processing package linux-firmware (--configure): subprocess installed post-installation script returned error exit status 1 Processing triggers for initramfs-tools (0.122ubuntu8.16) ... update-initramfs: Generating /boot/initrd.img-4.4.0-179-generic
gzip: stdout: No space left on device E: mkinitramfs failure cpio 141 gzip 1 update-initramfs: failed for /boot/initrd.img-4.4.0-179-generic with 1. dpkg: error processing package initramfs-tools (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: linux-firmware initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1)
df -h:
Filesystem              Size  Used
Avail Use% Mounted on udev 7.8G 0 7.8G 0% /dev tmpfs 1.6G 170M 1.4G 11% /run /dev/sda2 234G 7.6G 214G 4% / tmpfs 7.9G 44M 7.8G 1% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup tmpfs 1.6G 16K 1.6G 1% /run/user/1000 /dev/sda1 189M 161M 15M 92% /boot
Maybe 190 MB is to small? How can I increase size? (It's a distant server, I can't use live USB.)
Maybe another solution?
Eliah Kagan
  • 119,640
Matrix
  • 129
