This page https://developer.download.nvidia.cn/compute/cuda/repos/ubuntu1804/x86_64/ list lots of drivers.
I need to install the version nvidia-driver-440_440.33.01-0ubuntu1_amd64.deb because my dmesg is saying:
NVRM: API mismatch: the client has the version 440.33, but
NVRM: this kernel module has the version 440.100. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version.
after I run
docker run --gpus all nvidia/cuda:10.0-base nvidia-smi
So I need the specific version 440.33
I tried downloading and installing:
sudo apt install -y ./nvidia-driver-440_440.33.01-0ubuntu1_amd64.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'nvidia-driver-440' instead of './nvidia-driver-440_440.33.01-0ubuntu1_amd64.deb'
nvidia-driver-440 : Depends: libnvidia-gl-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: nvidia-dkms-440 (= 440.33.01-0ubuntu1)
Depends: nvidia-kernel-source-440 (= 440.33.01-0ubuntu1) but it is not going to be installed
Depends: libnvidia-compute-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: nvidia-compute-utils-440 (= 440.33.01-0ubuntu1) but it is not going to be installed
Depends: libnvidia-decode-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: libnvidia-encode-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: nvidia-utils-440 (= 440.33.01-0ubuntu1) but it is not going to be installed
Depends: xserver-xorg-video-nvidia-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: libnvidia-cfg1-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: libnvidia-ifr1-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Depends: libnvidia-fbc1-440 (= 440.33.01-0ubuntu1) but 440.100-0ubuntu0.20.04.1 is to be installed
Recommends: nvidia-settings but it is not going to be installed
Recommends: nvidia-prime (>= 0.8) but it is not going to be installed
Recommends: libnvidia-compute-440:i386 (= 440.33.01-0ubuntu1)
Recommends: libnvidia-decode-440:i386 (= 440.33.01-0ubuntu1)
Recommends: libnvidia-encode-440:i386 (= 440.33.01-0ubuntu1)
Recommends: libnvidia-ifr1-440:i386 (= 440.33.01-0ubuntu1)
Recommends: libnvidia-fbc1-440:i386 (= 440.33.01-0ubuntu1)
Recommends: libnvidia-gl-440:i386 (= 440.33.01-0ubuntu1)
