I am a 12 hours Ubuntu 20.04 user old, came from windows 8.
my problem is that I have another monitor and want it to "extend" the display Join Displays but for a reason, both of the screens won't display together it's either the laptop screen or the external monitor. If I closed the laptop lid, then the external monitor will display, and if I opened the lid, the external monitor will show its screensaver animation and the display will be on the laptop's screen.
This is the display settings from laptop screen:
this is the display settings from laptop screen
this is what typing xrandr --query will show
Screen 0: minimum 320 x 200, current 2390 x 968, maximum 16384 x 16384
LVDS connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      59.99*+
   1280x720      59.97
   1152x768      59.95
   1024x768      59.95
   800x600       59.96
   848x480       59.94
   720x480       59.94
   640x480       59.94
VGA-0 connected 1024x768+1366+200 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768      60.00*
   800x600       60.32    56.25
   848x480       60.00
   640x480       59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
Graphics card: Radeon HD 7640G and no updates in Additional Drivers tap in Software & Updates window.
any possible solution to make both of the screens work together?
UPDATE: I installed Linux mint 20 cinnamon edition, Fedora 32 and the problem still occurs.
Looking at the xrandr output, both displays are seen by your hardware. Your external monitor seems to be connected with VGA and has a resolution of 1024*768 But it also looks like the external display does not fully specify itself (edid) because it reports a physical size of 0mm x 0mm It also seems to be shifted vertically by 200pixels, the defined viewport is 2390 x 968 but this should not be a problem.
Since you already used xrandr we can try the following in a terminal
xrandr --output VGA-0 --off
This should switch off the external monitor. Now we switch it back on with it's preferred setting and putting it on the right side of your laptop screen :
xrandr --output VGA-0 --auto --right-of LVDS
Should this not work, a detailed description of your hardware might be needed, to see which driver is used for the hardware. Please share ~/.local/share/xorg/Xorg.0.log
Ferdi
  • 527
It might sound obvious, but did you checked in the bios settings of your laptop if there is not a setting that managed how your graphic adaptor behaves? I have a Thinkpad where I have to define whether the Intel or Nvidia graphic adaptor should be used... Windows might handle it automatically, Ubuntu not..
