I need to install both 32 and 64 bit versions of musl-tools, but whenever I try to install one the other is automatically uninstalled. If I try both at the same time I get conflicts:
$ sudo apt-get install -y musl-tools gcc gcc-7 cpp binutils musl-tools:i386 gcc:i386 gcc-7:i386 cpp:i386 binutils:i386
binutils : Conflicts: binutils:i386 but 2.30-21ubuntu1~18.04.3 is to be installed
binutils:i386 : Conflicts: binutils but 2.30-21ubuntu1~18.04.3 is to be installed
cpp : Depends: cpp-7 (>= 7.4.0-1~) but it is not going to be installed
Conflicts: cpp:i386 but 4:7.4.0-1ubuntu2.3 is to be installed
cpp:i386 : Conflicts: cpp but 4:7.4.0-1ubuntu2.3 is to be installed
gcc : Conflicts: gcc:i386 but 4:7.4.0-1ubuntu2.3 is to be installed
gcc:i386 : Conflicts: gcc but 4:7.4.0-1ubuntu2.3 is to be installed
gcc-7 : Depends: cpp-7 (= 7.5.0-3ubuntu1~18.04) but it is not going to be installed
Conflicts: gcc-7:i386 but 7.5.0-3ubuntu1~18.04 is to be installed
gcc-7:i386 : Conflicts: gcc-7 but 7.5.0-3ubuntu1~18.04 is to be installed
musl-tools : Conflicts: musl-tools:i386 but 1.1.19-1 is to be installed
musl-tools:i386 : Conflicts: musl-tools but 1.1.19-1 is to be installed
Here's essentially what I'd like to do:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install -y gcc-multilib musl-tools
sudo mv /usr/bin/{,x86_64-linux-}musl-gcc
sudo mv /usr/bin/{,x86_64-linux-}musl-ldd
sudo apt-get install -y musl-tools:i386
sudo mv /usr/bin/{,i386-linux-}musl-gcc
sudo mv /usr/bin/{,i386-linux-}musl-ldd
