I am not able to add or update any repositories on my PC. The following error encountered when I tried updating using sudo apt-get update
E: The repository 'http://ppa.launchpad.net/screenlets/ppa/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
This error mentions screenlets repository but I am getting the same error when I try to add any repository.I was getting the same error before adding screenlets repository.
The following are my specs fetched using neofetch:
OS: Ubuntu 18.04.4 LTS x86_64 Kernel: 4.15.0-109-generic
Packages: 1701
Shell: bash 4.4.20
CPU: Intel Core 2 Duo E7200 (2) @ 2.306GHz
GPU: Intel 4 Series Chipset
Memory: 1655MiB / 7848MiB
It is actually lubuntu 18.04
the question here is that not only I want to add repositories but also update the existing ones. Also, installing applications from snap is also not working but that could be a different thing altogether.
Screenlets does not provide version for Ubuntu 18.04, in fact it has not been updated since 16.10 (Yakkety).
Abandon screenlets
This will remove Screenlets ppa, effectively get rid of the problem altogether.
sudo add-apt-repository --remove ppa:screenlets/ppa
sudo apt update
Use old 16.04 source
If you wish to keep using screenlets, a quick workaround would be using the 16.04 (Xenial) source to install Screenlets.
sudo sed -i 's/bionic/xenial/g' /etc/apt/sources.list.d/screenlets-ubuntu-ppa-bionic.list
sudo apt update
There'll be no error produced, you can now install package provided from screenlets ppa.
Note that I have not tested this method because it's not something I want to (have to un-)do on my machine
As a side note, you may want to refer to this nice tutorial which explain in depth how to successfully install Screenlets on Ubuntu 18.04 (and 20.04 !).
Liso
  • 15,677
