Does sis have any drivers available for their 671/771 "video card" ? how can i install it and set it to 1280x800 resolution?
bain
  • 12,200
Ramalus
  • 113
This worked for 10.04 and 10.10(not sure of above)
First download the drivers
Use http://ajoliveira.com/ajoliveira/gen...t_10.04.tar.gz for the 32 bit driver and http://ajoliveira.com/ajoliveira/gen...t_10.04.tar.gz for the 64 bit driver, (take the install files), unzip them once unzipped copy or move them
Open up a terminal and go to the path you've unzipped them in.(use the cd command to navigate to directory's) i.e; cd /home/user/Downloads
sudo cp sis671_drv.* /usr/lib/xorg/modules/drivers/
type in your password and press enter
then stop X (We need to stop X or we won't be able to auto-generate a xorg.conf.new)
sudo service gdm stop
(you'll have to do next part blindly)
Code: Switch to tty1 by pressing Ctrl+Alt+f1 (f2 for tty2, f3 for tty3, etc.. (f7 should be X)
Even though you won't be able to read it (yet) you can login type in your username and press enter
type in your password and press enter Now you're logged in you want to become root; type;
sudo bash
Now your root; type in
Xorg -configure (this will create a xorg.conf.new in your home directory)
and start gdm again with
service gdm start
Once there; Open up a terminal again;
move the auto-generated xorg.conf.new to /etc/X11/xorg.conf with
sudo mv xorg.conf.new /etc/X11/xorg.conf and restart gdm by typing;
sudo service gdm restart
Fix the plymouth and the unreadable tty problem like this Open up a terminal and typ
sudo bash
enter your password type;
echo blacklist vga16fb > /etc/modprobe.d/blacklist-vga16fb.conf type
update-initramfs -u
and reboot reboot
After this if you do not have proper resolution then
Once you get to the desktop, start a Terminal and
cd /etc/X11 sudo nano xorg.conf That will open xorg.conf in order to be edited, find "Device" Section and set Driver "sis671" (If you're beginner do not change anything else). Now to exit and save make ^x, where ^ means CTRL.... in a few words CTRL-x will let you exit nano, remember to SAVE changes!
Ashu
  • 9,642
This is an easy how-to: http://sites.google.com/site/easylinuxtipsproject/sis
Pjotr123
  • 580
