Why does the error show during boot-repair? FYI: My external HDD size 4TiB.
ERROR: unsupported sector size 4096 on
I have my machine which shows as:
ubuntu@ubuntu:~$ lscpu
Architecture:                    x86_64
CPU op-mode(s):                  32-bit, 64-bit
Byte Order:                      Little Endian
Address sizes:                   36 bits physical, 48 bits virtual
CPU(s):                          2
On-line CPU(s) list:             0,1
Thread(s) per core:              1
Core(s) per socket:              2
Socket(s):                       1
NUMA node(s):                    1
Vendor ID:                       GenuineIntel
CPU family:                      6
Model:                           42
Model name:                      Intel(R) Pentium(R) CPU B950 @ 2.10GHz
Stepping:                        7
CPU MHz:                         892.831
CPU max MHz:                     2100.0000
CPU min MHz:                     800.0000
BogoMIPS:                        4190.35
L1d cache:                       64 KiB
L1i cache:                       64 KiB
L2 cache:                        512 KiB
L3 cache:                        2 MiB
NUMA node0 CPU(s):               0,1
Vulnerability Itlb multihit:     KVM: Vulnerable
Vulnerability L1tf:              Mitigation; PTE Inversion
Vulnerability Mds:               Mitigation; Clear CPU buffers; SMT disabled
Vulnerability Meltdown:          Mitigation; PTI
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled v
                                 ia prctl and seccomp
Vulnerability Spectre v1:        Mitigation; usercopy/swapgs barriers and __user
                                  pointer sanitization
Vulnerability Spectre v2:        Mitigation; Full generic retpoline, IBPB condit
                                 ional, IBRS_FW, STIBP disabled, RSB filling
Vulnerability Tsx async abort:   Not affected
Flags:                           fpu vme de pse tsc msr pae mce cx8 apic sep mtr
                                 r pge mca cmov pat pse36 clflush dts acpi mmx f
                                 xsr sse sse2 ht tm pbe syscall nx rdtscp lm con
                                 stant_tsc arch_perfmon pebs bts rep_good nopl x
                                 topology nonstop_tsc cpuid aperfmperf pni pclmu
                                 lqdq dtes64 monitor ds_cpl est tm2 ssse3 cx16 x
                                 tpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_d
                                 eadline_timer xsave lahf_lm epb pti ssbd ibrs i
                                 bpb stibp xsaveopt dtherm arat pln pts md_clear
                                  flush_l1d
IT's NOT EFI instead BIOS Bootable:
ubuntu@ubuntu:~$ efibootmgr
EFI variables are not supported on this system.
I have followed this article about BIOS-GPT Linux partioning process. The blogger confirms about possibilities of such installation in GPT Partitioned disk using BIOS based machine.
I have tried BIOS-GPT (option 1 and 3). None of those options worked to boot linux alongside with another OS (Win7) installed before in internal HDD.
The boot-repair tools gives the following result:
Both options shows:
=============================== StdErr Messages ================================
ERROR: unsupported sector size 4096 on /dev/sdc. ERROR: unsupported sector size 4096 on /dev/sdc.
Pastebin URLs: Option 1
